  • Guests: 66
Help with 833c vttc
Bamacoiler
Wed Sept 17 2008, 07:03PM Print
Bamacoiler Registered Member #1628 Joined: Wed Aug 06 2008, 08:48PM
I've been lurking around this forum for a while so I figured I would post to see if I could get some help.
I just finished my first VTTC. It's a single 833C closely following
Steve
> Ward's single 833A schematic. The specs:
> Secondary - 3.5" x 19" x #24
> Topload - 3" x 7.5" toroid, about 1" above the top turn.
> Primary - 29 turns #12 THHN on a 6.25" green pipe. Bottom turn level
with
> secondary bottom turn.
> Filament supply - rewound mot, 10V even (does get warm).
> Plate supply - very large (physically) old mot, voltage
> doubler 2.00uf, mo diode, 1800pf10kv ceramic disk
> Tank cap - 2nf 40kV doorknob > Plate filter - 11 turns #12 on 50ohm 20W
> Feedback coil - 22 turns #24
> Grid leak - 5k 100w fixed, 1800pf 10kv ceramic disk
> Everything is wired with #12 wire. All connections are tight.
> brand new rf parts taylor 833c
No staccato yet
I can't even get the coil to oscillate. I've tried switching polarity on the grid coil and a few other things. No plate glow at all and I can't even light up a flourescent light holding it right up to the secondary. All I got so far is the filament glowing lol. Help!!!
Edit: How do I know if the tube is good?
Dr. Drone
Wed Sept 17 2008, 09:18PM
shades
Bamacoiler
Thu Sept 18 2008, 01:20PM
Dr. Spark your a genius. That was it. I missed the ground on the filament lead. Thank you very much for that tip. First light with about 12 inch discharges. Off to tune the coil, thanks again.
Bamacoiler
Edit: Will post pics soon.
Bamacoiler
Fri Oct 03 2008, 12:32PM
I was tinkering with my 833c coil last night and noticed something that concerned me. I'm using a large rewound mot with shunts removed for the filament tranny. At 0% on the variac the filament pins measured 10.05v. When breakout occurs the filament voltage drops and fluctuates from 9.5v to about 9.8v. Should I add another turn or so on the primary or is this normal?
Dr. Drone
Fri Oct 03 2008, 04:17PM
shades
