  • Guests: 47
Stroker II
Dr Hankenstein
Sun Sept 14 2008, 09:51PM Print
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
Finally finished the last step of "Stoker II" DRSSTC engine....the snubber cap module. I was a little bit of a tight fit with those big 1.0uf/1600V CDE's. Stroker II was engineered by Dr. Spark and uses two CM600's in a 1/2 bridge configuration. The CM600 Hooper Drivers can be seen mounted on top of the CM600's. Hope to start winding the secondary soon.
Woo
Slideshow @ Link2
(I'm not sure how to make the "arrow-link" for the above link...)
1221429074 1642 FT0 Img 5203
1221429074 1642 FT0 Img 5205
1221429074 1642 FT0 Img 5206
1221429074 1642 FT0 Img 5209
Coronafix
Mon Sept 15 2008, 12:02AM
That's a little beast!! Nice work. Some larger pictures would be nice though.
Mon Sept 15 2008, 06:00AM
A well thought out design, and immaculately executed. amazed
Beautifull buswork, the cornerstone of every successfull DRSSTC. shades
At the end of the show, I was astonished that the editing software had not run out of transition effects. (liked the one with the CD that came rolling on the floor) cheesey
However: Was that a piece of electro galvanized steel allthread I saw you pass the current monitors on to?. cry
Cheers, Finn Hammer
Dr. Drone
Mon Sept 15 2008, 04:17PM
shades
Dr. Drone
Mon Apr 20 2009, 01:09AM
shades
Dr Hankenstein
Sat May 02 2009, 06:16AM
Well, I finally found some time to work on Stroker II. Here are some pics:
Now I have started on the power supply. Dual 20A Variac, meters, I will set this up to operate on dual voltage source: 120 or 240AC input.
01
22
 Primary
Space Needle
1241244879 1642 FT53929 Stroker Power Supply Parts
1241244879 1642 FT53929 Stroker Power Supply Front Panel
