  • Guests: 22
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
20kv 500w SMPS Supply
Fri Sept 12 2008, 07:12AM Print
I was contacted by a 4hv member wanting a supply good for about 20kv and 500w of power. So I built him this beast smile
It is based off of the standard mazzilli driver (gate resistors upped to 900ohms to prevent unwanted oscillations that seem to be present in very low inductance designs) that feeds a home wound flyback transformer that was made exactly like my previous thread Link2 and Link2 (second post) that feeds a voltage doubler made out of a 5nf 'plastic' oil/film cap (you know the red glass encased ones) and a string of about 40 uf4007 diodes to form a voltage doubler like is found in a microwave oven. I also added a little smps out of a power brick for an external dvd-burner to run the gate drive, and stuffed it all in an ATX power supply case. To get the hv out I made a custom connector that was basically a banana jack surrounded by a piece of 1/2" PVC pipe, that is plenty long to keep the arcs away from fingers and the like. I enlarged the fan hole in the supply and added a piece of smokey polycarbonate (painted black on the back) to make everything look nice and pretty.
The flyback driver (built using one of my PCBs that are for sale it anyone needs them) and the beginnings of the flyback transformer
1221202751 56 FT0 Driver 1221202805 56 FT0 Transformer
Overall view of the guts (I used insulators made out of 1/8" poly to keep sparks from forming where they shouldn't) and the finished supply
1221202868 56 FT0 Overall 1221203264 56 FT0 Overall2
Output without flash and with a flash (that is a hot arc!)
1221203305 56 FT0 Noflash 1221203341 56 FT0 Flash
the wires on that jacobs ladder are just over 6" long as measured from the point where the arc initiates to the tip.
I am working on a video, and a more detailed build description. But its midnight and I have my last day of work for the summer tomorrow...
Fri Sept 12 2008, 01:50PM
That is really cool! Did he exclusively want a current limited supply? If not, there will be big problems with output voltage dropping under load...
EDIT: it runs off a rectified mains?
Fri Sept 12 2008, 02:24PM
He is planning mostly to draw arcs off of of (for production of NOx among other things_, which will work best with this type of supply. And it runs off of 0-50v @ 15a (at full power it can do 750w) fed into the banana jaks on the back. I am still working on a main powered supply, which will be really sweet if I ever get it working (no external power supply needed).
BTW, it came out at 49.7oz, so its a tad bit lighter than a resonant mot supply wink
Fri Sept 12 2008, 03:31PM
Neat, and you managed to fit everything in a little PSU case. I've been considering making something like this myself for capacitor charging.
Fri Sept 12 2008, 03:39PM
Does your flyback core get hot? Mine always gets smoking hot with the zvs driver...
Do you have a gap in the flyback core/DC choke?
Fri Sept 12 2008, 04:46PM
The primary (6+6 turns wound out of some roughly 14awg litz wire I extracted out of a slr cap charger), secondary (34awg wire, about 750 turns in 8 layers), and core (about .2in^2 crossectional area) do not heat more than a few degrees than ambient. I have a small (probably about 5-10 mill) gap in the flyback, and am using a powdered iron dc choke (wound with about 80 turns of 16awg magnet wire, it heats about 10-20degrees above ambient in jacobs laddar duty)
Your core is probably saturating. I found this core is good for about 25v/turn at 25khz (which is where it is running in those pictures), but that was right on the edge. To find that I put a ferrite donut (one of the goldmine cores) on one of the primary leads, wound a 10 turn sense winding, put it into a 1r/10w low film resistor soldered to a heatsink, and noted when the primary current shifted from a sine wave to a triangle wave, and backed things off a few volts. When running in saturation the core did heat appreciably.
What does get hot is the bottom of the case. I am not sure if it is heat from the heatsinks on the tranformers (extended runs at >500w gets them to about 130f) or if I made a induction heater, but it will often be the hottest part of the supply amazed
One thing I will point out is that the mazzilli drive does not like capacitor charging in any way shape or form. If works fine with doubler arrangements, etc, but trying to charge a large capacitor throws off the resonance somehow and just causes all sorts of problems.
Fri Sept 12 2008, 06:16PM
THanks for the reply, I dont think the core is saturating as I can see a nice sinewave through the primary, but enough OT.
When I made my flyback driver in a PC PSU case, the case DID heat up around the core. So yes it is a mini induction heater smile
Sat Sept 13 2008, 04:17PM
I've charged big capacitors fine with a Mazzilli. I used a full-wave doubler with grossly undersized capacitors to feed the main cap. The small capacitors act as a ballast to limit the charging current and stop it from messing with the resonance too badly.
GeordieBoy
Fri Sept 19 2008, 12:48PM
> I am not sure if it is heat from the heatsinks on the tranformers... or if I made a induction heater...
If there is a gap in the ferrite core and it is run at high flux density, then it is possible that fringing flux from the core will heat surrounding metal. Copper windings in "high-power" flyback transformers are often kept away from the immediate vicinity of the air gap to prevent them overheating due to fringing flux.
20'c temperature rise for the iron powder core sounds reasonable, but if it gets too hot it could start to deteriorate with thermal ageing. Something to keep in mind if the supply will operate continuously in a high ambient temperature environment.
-Richie,
Fri Sept 19 2008, 06:09PM
Sorry for any confusion, I use degrees fahrenheit, so about 10c temp rise. Should be good for a long time.
