  • Guests: 41
Tube tesla coil calculator
Tue Sept 02 2008, 03:37AM Print
Can the calculator to find secondary resonant frequency at this site Link2 be used to find the secondary resonant frequency in tube Tesla coils? All you do is give it the amount of wire you will be using and it gives you secondary resonant frequency, seems almost too easy.
Tue Sept 02 2008, 04:29AM
Calculating the resonance frequencies in secondaries with topload and primaries with cap tank should be the same for SGTC and VTTC, but i do stand by to get corrected :)
You could also use the JAVATC calculator, thats what I used to plan my VTTC with.
Tue Sept 02 2008, 04:32AM
however I am suspicious because all it asks for is the length of wire and nothing else. Will the calculator work reliably? I need to wind three different primaries for a science fair project.
Firefox
Tue Sept 02 2008, 05:01AM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Use this version of the calculator. If you are using a VT to switch the current, then you don't need to worry about the primary resonance, only the proxcimity inductance it adds to the secondary. In that light, just build everything correctly except the resonant capacitor, as the switch will take care of the resonance.
Coronafix
Tue Sept 02 2008, 08:20AM
A coil is a coil, regardless of how it is being driven (spark, tube, igbt, mosfet, fart power :0)
That calculator comes close but can't give you the exact frequency.
With a tube driving the secondary, the feedback coil will find the resonant frequency and drive it there.
Of course it all depends on the tube as to the size of your secondary.
