  • Guests: 57
12/25 Kolas (18)
12/26 buxtronix (50)
Mosfet ratings
ped
Thu Mar 23 2006, 08:00PM Print
ped Registered Member #305 Joined: Sat Mar 11 2006, 04:27PM
Hi guys, Got my SSTC working with help from all of you, but its developed a problem, the IRFP450's shorted out after a while, i wasnt "pushing" the coil, it was well within operating limits (designed for 110VAC, i was running it between 90-100VAC) , so my question is this, i have four IRFP460's , can i double up on the output stage, it currently uses 2 >> see here>> http://4hv.org/e107_plugins/forum/ forum_viewtopic.php?3804 , can i mod the circuit so i can use four IRFP's to help it handle current better? the gate circuit uses 15v zeners, are these absolutlely neccesary as i dont have any more?
thanks in advance
Thu Mar 23 2006, 08:17PM
You need zenners on gates to protect them
You can parallel the FETs, each gate with its own resistor for ringing suppresion. Keep the connections short, and equally shared by each FET.
EEYORE
Thu Mar 23 2006, 08:31PM
IRFP450s are just dissapointing if your looking for "fun" output. cheesey
Use an interruptor and keep their on times really low...
Matt
ped
Thu Mar 23 2006, 09:10PM
mattrg2 wrote ...
Use an interruptor
Matt
a what? angry the circuit is ready made? , look at the link in my origonal post to see what i mean
EEYORE
Thu Mar 23 2006, 10:21PM
ped wrote ...
mattrg2 wrote ...
Use an interruptor
Matt
The link doesnt work. When i paste itinto the browser, it just sends me to an error page.
Matt
ped
Thu Mar 23 2006, 10:26PM
hmmm no it doesnt work, its on page 2 of the this tesla coil forum, quarter of the page down "GDT problem with my SSTC" or something like that :)
EEYORE
Thu Mar 23 2006, 10:55PM
ped wrote ...
Ok i see it now. What i would do,have done before, is pop out that 555 and make an interruptor. Pulse the enable pins on your gate drive chips(if they have them) are they ucc37321/ucc37322?Enable is pin 3 on them.
An interruptor is basically a 555(most common) running as an oscillator. You adjust its freq and duty cycle via external pots. This limits how long your transistors can stay on for ect.
Matt
Fri Mar 24 2006, 07:07AM
Even with an interrupter, the FETs can blow if you draw short arcs too ground. Consider increasing the primary turns a bit to add more safety load for your FETs. I poped some 460 FETs with a 4-6 turns primary, but never did with 10 turns.
Desmogod
Fri Mar 24 2006, 07:34AM
How many primary turns are you running? I used to use IRFP450's and they really are kinda weak.
And they _hate_ being run CW.
also, my halfbridge throws all the toys out of the pram at about 140+V.
ped
Fri Mar 24 2006, 08:13AM
hi, im running 10 turns at the moment i think, mayby use thinner gauge wire?
1143188015 305 FT5317 Dscf0001
