  • Guests: 41
High Voltage Divider for Multimeter
Firefox
Sat Aug 30 2008, 02:47AM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I was thinking about my next project (HV CW Multiplier), and realized that I am going to need an accurate way of reading the input voltage of my transformer to make sure I get the voltage I want out of the multiplier without killing it. So for my question: Are there any dangers to using high value (20-100Mohm), 10kV resistors to make a 10 or 20 resistor chain and just probing the voltage across the final resistor with a normal DMM? Also, is there a better way to make a divider than a simple resistor chain?
One final thing; so as not to kill the diodes, is there also a good way of making an HV milliammeter, or will a normal voltage milliammeter work?
Sat Aug 30 2008, 04:27AM
A lot of people will use the internal resistor in the voltmeter (usually about 20meg) as the lower half of the divider and use a high resistor (in the gigohm range) for the ther half. At least then you don't have to worry about the resistors flashing over since you have like 50 of them...
Also, normal ammeters work for HV, just be sure they are well insulated! Also, if you can put them in the low voltage side of your hv supply...
Myke
Sat Aug 30 2008, 05:26AM
I thought a normal 1KV max voltmeter's resistance was around 1meg. Hmm... though 1meg would load down circuits pretty easily I think.
Firefox
Sat Aug 30 2008, 06:16AM
I can take the back off of my 500VAC/500VDC/200mA multimeter and use my .01ohm-20Meg ohm meter to measure the resistance of the meter's resistor. I've looked at it before, and it has the different resistors marked based on the input.
aonomus
Sat Aug 30 2008, 07:17AM
Sometimes the meter impedence is listed on the DMM somewhere on the back, or on the packaging/manual.
Also, Link2
Sat Aug 30 2008, 07:36AM
Maybe it would be better to make a HV resistor chain and measure the current flowing through it?
Firefox
Sat Aug 30 2008, 04:06PM
I would use many 50 megaohm+ resistors, so I don't think It will be a problem. My DMM's current chip is fried as far as I know, anyway, and I don't have any more cheap DMMs to blow up.
