  • Guests: 53
Can UCC37322/37321 be built on a breadboard?
Mokuan
Thu Aug 28 2008, 08:41AM Print
Mokuan Registered Member #1509 Joined: Thu May 29 2008, 05:53AM
I am planing to test both of them together with a PLL CD4046 on a breadboard. (my design is referencing Dr. Conner and Uzzors' PLL SSTC design)
Links:
I know the output of the UCC37322/37321 is 9A, so I am wondering whether they are capable to be tested on a breadboard or not.
Can anyone answer my silly question?
Many thanks!! amazed cheesey smile tongue
Avi
Thu Aug 28 2008, 10:31AM
worked for me (driving mosfet gates and GDTS)
Thu Aug 28 2008, 02:40PM
Yes you can, it won't pull 9 amps all time.
Thu Aug 28 2008, 05:44PM
It might... What frequinecy are you planning to use, and what type of mosfets?
If you are using a low frequiency, and a small load (small halfbridge of irfp450 or the likes) you should be OK as long as you put a good quality decoupling cap as close as you can to the supply leads of the chip (ie, use a cap with long leads and stick it directly across pin 5/8 or whatever the power pins are on your gate driver).
If you are trying to run at MHz frequneecies with a fullbridge of 55n50's or something you are going to have trouble...
Mokuan
Fri Aug 29 2008, 07:59AM
Ok, I will try it out, thanks for answering! :)
Tom540
Fri Aug 29 2008, 08:09PM
Tom540 Banned on 3/17/2009.
Mokuan wrote ...
Links:
The 9 amps is only peak pulsed current. It's unlikely that the gate driver chips will actually ever need to pulse that much current.
Fri Aug 29 2008, 08:54PM
Here is the first prototype of my PLL driver. The UCCs are the two chips on the left.
1220043242 30 FT53031 106 0666 Pll Breadboard
Mokuan
Tue Sept 02 2008, 04:48AM
Thanks a lot!
I will just have a try and to see how it goes.
cheers~~ wink
