  • Guests: 50
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Cheap 3.3nF 4kV Russian Caps on Ebay
Firefox
Tue Aug 26 2008, 08:55PM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I saw this when surfing around ebay today, and figured I had to share this sale with you. Quality is probably questionable, but at 13 dollars for 100 caps, I figured it wouldn't be a terrible thing to be proven right or wrong.
3.3nF 4kV Capacitor
Edit: Also found these browsing around his store. Quality even more questionable, but here they are none the less.
1.5kV 2A diodes
Tue Aug 26 2008, 09:32PM
datasheet: Link2
their capacitors does not seem to have very high du/dt rating :/
Tue Aug 26 2008, 11:55PM
I had the same caps but they where 4kv and 6800pf (6,8nf) And they where actually pretty good. I had 3 in series and enough parallel to equal 16-20 nf.. i do not remember. They only lasted about 5-10 minutes but i bet they would work kinda ok for a marx or something similar.
