  • Guests: 49
SLR overheats, feel frustrated, please help!!!
baleworker
Mon Aug 25 2008, 05:55PM Print
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
As soon as I solve one problem with excessive heat, another one arises. Its like there is a need for place to dissipate the heat!
So, capacitors are fine now, but the inductor in series with primary overheats, and its made of 3 smaller diameter wires to account for skin effect and well overrated.
If I remove the inductor, transformer will take the heat!!!
My guess is because the idle voltage is around 10kV and once the arc ignites it drops to 1-2 kV, excessive voltage need to drop across something else and all that power gets dissipated. Is it right?
Also, I noticed that as I get to 75-100% duty cycle, the idle voltage drops to around 7kV at 100%, why would that happen???
Please help!!! I really need an advice from an experienced professional like you guys.
Oh an UF4007 also heat up considerably, though they survive with the forsed air cooling.
Mon Aug 25 2008, 06:29PM
baleworker wrote ...
No, ideal inductor does not dissipate any power. It does "drop" power but only apparent one. The heat generated is because of current flowing through ohmic resistance of the inductor, so winding with thicker wire should help.
I don't know, maybe at 50% you're exciting some parasitic resonance in the transformer which goes away at higher duty cycles. I have noticed this when playing with LOPT's.
Maybe you should define what "hot" means? Most semiconductors and magnet wire are designed for 150°C, so unless they are running over 100C you shouldn't worry. However watch the temperature of ferrite cores, they should NEVER get over 100C if you don't know the material.
Firefox
Mon Aug 25 2008, 07:05PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
The SLR topology is designed to run at 25-50% duty cycle, this is what makes the circuit work as it is designed.
Mon Aug 25 2008, 07:55PM
Firefox wrote ...
The topology will work at 100% duty just fine, what can get impacted is the open circuit performance of the transformer.
Ken M.
Mon Aug 25 2008, 10:43PM
Wouldn't 100% duty cycle mean its a dc voltage? since 50% duty cycle is Ton .5 and Toff .5, so thn wouldn't 100% be Coninualy on or continually off?
baleworker
Tue Aug 26 2008, 01:24AM
here is a waveform of what I call 100% duty cycle for SLR:
Sry if I confused you guys
Electroholic
Tue Aug 26 2008, 07:04AM
are you only half wave rectifying the output? why does the top trace look like that?
Tue Aug 26 2008, 08:35AM
Thats what I call 50% duty cycle, or close to that. However it seems youre slightly below 50%, try increasing the duty a bit to something like 60%, here more is better than less.
Tue Aug 26 2008, 11:35AM
Are you sure? I'd have thought that running a SLR at 50% or above would be asking for trouble with DC offsets and the like. It seems to me that you ought to let the second half-cycle end by itself, to make sure the current is zero and the inductor and transformer are reset, before you go turning anything on again.
Tue Aug 26 2008, 11:46AM
Well when the current conducts through the clamp diode, it really does not care if the device is on or not. I have ran a SLR converter at 100% duty and the primary waveform was the same.
