  • Guests: 24
Avi (41)
Jannick Hagen (15)
07/10 Sparcz (69)
07/11 Bfeigum (35)
07/12 genious 7 (32)
my 1st drsstc now complete.
first  2 3 4 5
teslacoolguy
Fri Oct 24 2008, 01:59PM
Well if that does happen that is what i will do. The capacitor bank is only going to have 3.5kvp-p and the capacitors that are closest will be at the same potential so don't really think it is of much concern.
Fri Oct 24 2008, 02:35PM
If I was you I would do it before the problem occurs. But it is up to you. All this looks great so far.
Danielle
Fri Oct 24 2008, 05:49PM
Danielle Registered Member #632 Joined: Mon Apr 09 2007, 01:09AM
the arcing would cause the LC frequency set to go dramatically off, possibly causing the system to attempt to switch at a frequency in the Mhz, destroying your switches.
teslacoolguy
Sat Oct 25 2008, 12:31AM
Ok you have me convinced cheesey i will use the dremel and cut away between the capacitors to prevent a arcover. Anyway i mounted the legs to the top and bottom and this is how it looks.
1224894641 1107 FT52798 Dscn3801 640x480
Man it is looking better every day.
teslacoolguy
Sun Nov 02 2008, 06:15PM
Update. I have the igbt's and i started the bridge. I also got the gdt and ct ferrites so i made those to. here are some pics about how things are coming along.
1225649661 1107 FT52798 Dscn4006 640x480
1225649661 1107 FT52798 Dscn4008 640x480
1225649661 1107 FT52798 Dscn4019 640x480
teslacoolguy
Thu Nov 06 2008, 03:40AM
Another update. The H Bridge is complete and things are coming together nicely. I still need to mount a couple of components but for the most part, it is complete. First light may be as early as this weekend depending on if i get the last order of parts by then. Anyway, here are some pics of everything firmly mounted and almost ready.
1225942766 1107 FT52798 Drsstc 1
1225942766 1107 FT52798 Drsstc 2
1225942766 1107 FT52798 Toroids
I still need to support the bus cap from the bolt in the back and add a snubber cap across the supply rails. Be sure to tell me how it is looking or if there are any glaring mistakes that i made. Thanks.
Mike
Thu Nov 06 2008, 11:56PM
Mike Registered Member #58 Joined: Thu Feb 09 2006, 05:40AM
mmm very nice :) I hope it works really well :D
teslacoolguy
Fri Nov 07 2008, 12:04AM
Thanks. Here is another update, i connected the gates and soldered all the wires onto the controller board. All i have left now is to connect a bridge rectafier and conect the low voltage transformer for the control circuitry. Planning on low power tests over the weekend. Here is a updated pic.
1226016171 1107 FT52798 Drsstc Gates Mounted
teslacoolguy
Sun Nov 09 2008, 04:13AM
Complete!!! I tested it today but it did not work but i think i know why. Tomorrow i will do alot of scoping around to try to trace down the problem. Anyway here is a pic of the beauty!
1226203897 1107 FT52798 Drsstc Complete
Here is the link to a hi res pic on flickr. Link2
Sun Nov 09 2008, 10:41AM
Wow that coil looks great. Did you swap the input leads on the gdt. It's most likely a phasing problem when a DRSSTC doesn't work. Hope to see some sparks coming from the top very soon.
first  2 3 4 5
