  • Guests: 53
Michael Witt (36)
AleSeg (15)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
my 1st drsstc now complete.
teslacoolguy
Sat Sept 13 2008, 10:33PM
Yep. toilet drain plug shades Simple and effective. Actually the box is just a aluminum project box from radioshack. I am working on the interrupter so it will probably be done by tonight.
teslacoolguy
Wed Sept 17 2008, 12:32AM
I finally got all the bumps out of the interrupter and finished that up. I just finished making the primary so here are some pics. tell me what you think.
1221611506 1107 FT52798 Interrupter
1221611506 1107 FT52798 Coil  Primary
Bennem
Wed Sept 17 2008, 05:30AM
Hi teslacoolguy,
It's coming together real nicely!
I see that you are using Steve Wards latest DRSSTC circuit,
do you plan to use his mod's too that he used to help
make primary strikes ok?
i think he placed a ferrite bead on his GDT primary input lead
and a cap from his bus supply to ground.
All the best,
Mel.
teslacoolguy
Thu Sept 18 2008, 08:00PM
thanks. I am using Steve Wards latest driver circuit. I am going to do the mod to make primary strikes ok but i added a strike rail just for that extra protection shades. Just as a update, Mouser shipped the caps yesterday so i should have them by mid next week.
Sat Sept 20 2008, 07:30PM
Wow, Great coil. And you are still only 15! WTH?!
teslacoolguy
Thu Oct 23 2008, 04:17PM
bump... Now that i am back in ohio for a little while, i now have tome to work on the drsstc. I finished up the mmc and im going to work on the base right now. I will post some pics tonight.
teslacoolguy
Fri Oct 24 2008, 04:23AM
double post.. sorry but i have a big update. The mmc is finished and everything is in it's position less the H bridge. The igbt's still havent come yet so that is really the only thing holding me back on that. Here are some pics.
1224822168 1107 FT52798 Dscn3798 640x480
1224822168 1107 FT52798 Dscn3799 640x480
1224822168 1107 FT52798 Dscn3800 640x480
Danielle
Fri Oct 24 2008, 04:39AM
Danielle Registered Member #632 Joined: Mon Apr 09 2007, 01:09AM
I would say to watch out when building a MMC on a breadbord like that, HV plus small hole spacing = arc over..... just something to think about
Fri Oct 24 2008, 05:33AM
Indeed, happened to me once in a small SGTC
Fri Oct 24 2008, 06:05AM
Just use a Dremel tool to grind the copper away.
