  • Guests: 134
Dual MOT Tesla Coil
Alexandre
Sat Aug 23 2008, 05:38PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Good day coilers!!!!
This is my new dual mot tesla coil amazed
Its a 2 MOTs conect in series about 4.5kv @ 450ma
20nf CAP Bank
Secondary 30cm x 10cm # 30
6 primary turns of 1mm wire rolleyes
The sparks come close to 45cm shades
Her is the video tongue
Alexandre
Estragon
Sat Aug 23 2008, 08:29PM
Estragon Registered Member #1391 Joined: Fri Mar 14 2008, 04:49PM
Wow! That much spark with just to MOT's?! Waaaaaa!
Are they current-limmited?
How much did the MMC bank cost in total?
And thats a stike rail right?
guich
Sat Aug 23 2008, 09:22PM
guich Registered Member #1269 Joined: Sat Jan 26 2008, 06:22PM
A friend of mine got 1.50metre sparcs with two mots! So keep on building TCs smile
Alexandre
Sun Aug 24 2008, 01:54AM
The MOTs are limited by a ballast
For this fact I did not a very large spark, yet I want to put total power, this is about 2.7kW ...
Certainly the spark will increase if you add more power .. cheesey
Cain
Sun Aug 24 2008, 04:32AM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
are you running dc or ac? i am up to 1.5 metres with 2 mots (although shes developed a no go state at the moment :() get the size of your tank circuit bigger bigger bigger.. 1mm will get warm i would expect lol I'm running 1/4 inch copper pipe and the tuning point warms up on mine
Alexandre
Sun Aug 24 2008, 03:53PM
I'm running it on AC, I am thinking of placing a doubler .. cheesey
In your coil you use two resistors in place of choke?
What value of each? wink
Cain
Tue Aug 26 2008, 12:17AM
100Ω 100W wire wound resistors
Seoul_lasers
Tue Aug 26 2008, 11:50AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
Cain wrote ...
I'd be care about pushing more than 2Kw through these as they will start to get roasty quickly. On my NST supply 4XMFRs 240mA 12Kv -- they get quite HOT!
It works to arrest any inbound feedback from the TC, but seriously thinking about upgrading to 1500W resistors, or just making my own.
I too have built MOT supplies, last one was a asymmetrical 5 pack which produced 11.5Kv @ 400-500mA, for short bursts, and could draw up to 1A on it. I ended up welding a metal table to the ground with it by accident. Not something to play around with.
Unfortunatly this supply never made it to become a PSU for a TC.. :( sad...
sad
Cain
Sat Oct 25 2008, 02:56PM
i have never noticed them warming up at all
Robert2
Sat Oct 25 2008, 06:56PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Nice, have only 1 MOT, sec.: 40cmx16cm of 0,18mm wire, 20nF cap bank, and i don't have primary coil :D
I make today spark gap, and first power in bad secondary (17cm x 11cm of 0,2mm wire) and have max 5cm spark :/ i don't have primary coil for a secondary coil ( 16cm Thickness sec.) :P I like TC! :P\
Photo of spark gap( he are very hot)
E449bfc52eedbd9e
And all:
752d41f5a4c5b525
I cant today switch on ths becouse TV and computer in all my house bad worked :D
