  • Guests: 41
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
Thermoelectric Cooling
Dragon64
Mon Aug 18 2008, 10:27PM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
I understand that a thermocouples are used to generate electricity when one side of two different metals are either heated or cooled. When electricity is applied to the thermocouple, one side gets warmer and the other side becomes cooler.
Im trying to build a fully operational thermoelectric cooler for various reasons but am stuck at many part of the design.
I did some reasearch about thermoelectric cooler but not much information are avaliable.
I need help with the design of the device and the material
TwoSpoons
Mon Aug 18 2008, 10:58PM
TwoSpoons Registered Member #1621 Joined: Tue Aug 05 2008, 05:26AM
You will need to use semiconductors. If you use metals then the thermoelectric cooling will be completely swamped by resistive heating.
aonomus
Mon Aug 18 2008, 11:20PM
You'd want to find a peltier module, its a thick chip basically, it has a bunch of those junctions and transfers heat from the cold side to the hot side. You will need a big heatsink on the hot side, and a plate on the cold side to clamp the peltier. The cold side can get cold enough to form ice crystals while the hot side can get hot enough that without the heatsink, it would self-desolder.
You can typically find the peltiers online, or as big heatsink/TEC assemblies scrapped out of camping coolers typically.
Example: Link2
Shaun
Tue Aug 19 2008, 12:17AM
Just be aware, larger peltier modules are extremely power-hungry. I have one such peltier unit, about 2"x2", and its rated for about 20A draw at 16V.
Dr. SSTC
Tue Aug 19 2008, 05:25AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
i agree bwith shaun you'll probably need to make a 14v rms smps to get that sort of power
aonomus
Tue Aug 19 2008, 06:41AM
You could always try Uzzors MOT PSU ( Link2 ). He basically took a MOT, took the HV windings out and rewound some windings to give him the voltage he wanted. I'm sure that if you used big enough wire you could get 14V at an absurd amount of amperage.
Dragon64
Tue Aug 19 2008, 06:52AM
Maybe a Thermoelectric cooler is too much work.
The main purpose for my thermoelectric cooler was to create a cooler capable of freezing while being silent. The cooler was designed house my bacterial colonies for later uses.
Fraggle
Tue Aug 19 2008, 08:43AM
Overclockers call this stuff `extreme cooling` and a wealth of information on heat pumps of all kinds can be found on their websites.
Tue Aug 19 2008, 02:21PM
Fraggle wrote ...
Nah it isn't that extreme, dry ice cooling and liquid nitrogen cooling is extreme. And fun to play with.
Fraggle
Tue Aug 19 2008, 07:03PM
I`d agree with you on the TECs but some of those mad cascades are pretty darn extreme and colder than dry ice to boot ;o)
