  • Guests: 41
Coillah's First Coil
1 2 3 4  last
coillah
Mon Aug 18 2008, 02:55AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Hey guys
as some of you know, I have been busy lately buying up stuff for my first coil. Thus far I have collected:
15kv 30ma NST
24AWG
24 Cornell Dubillier Caps, 2000V .15uF
I bought a 4" dia pvc form, cut to 26"(20" winding) for the secondary
.25" copper tube for primary
lexan for housing the static spark gap and caps
Now my current concern is the sealant for the secondary. I bought a brand of Rustoleum, clear latex sealant. Will this work?
Here are some pictures of my progress:
Coil Mark 1
Herr Zapp
Mon Aug 18 2008, 11:37PM
Coillah -
I'd be cautious about using any latex-based "sealant" to seal a TC secondary. Generally, latex paints and coatings are water-based, and intended for use on porous materials (wood, dry-wall,etc).
On a secondary with a PVC coilform, the coating may tend to trap some moisture between the windings and the PVC form. Eventually, all the moisture should diffuse out of the coating, but it could take quite a while.
I'd just go with conventional solvent-base polyurethane varnish, and not have any worries about potential moisture entrapment.
Regards,
Herr Zapp
MOT_man
Tue Aug 19 2008, 01:22AM
Solvent base clear coat ONLY. Urethane --- NEVER water based products!
+ it dries faster!
coillah
Tue Aug 19 2008, 03:24AM
duely noted guys. thanks for the reply :)
how's the secondary look?
Andyman
Tue Aug 19 2008, 07:14AM
Looking good! I like how..um..red..it is. I remember on my coil I would just sit there stroking the windings because of how smooth they were tongue
coillah
Tue Aug 19 2008, 02:29PM
Dude, hahah I forgot I left those pics up
They are now my facebook default images XD
EvanLAB
Mon Aug 25 2008, 11:07AM
EvanLAB Registered Member #1452 Joined: Thu Apr 24 2008, 09:24AM
Hello!
Very beautiful coil, eye pleases! Smart work! Coillah, very interestingly, what is the time you on spent for winding (without a covering a varnish)?
The matter is that I wound in manual, having spent 7 hours of continuous work! Thought that I shall keep within hour in 2...3. Next day the back and hands strongly hurted. As it is necessary to make from time to time various TC, I think the machine tool will be expedient...
Cheers!
Tom540
Mon Aug 25 2008, 09:48PM
Tom540 Banned on 3/17/2009.
MOT_man wrote ...
+ it dries faster!
Ive tried water based varnish before and the only problem i had with it is it wasn't as durable. Other that that it works fine.
coillah
Tue Aug 26 2008, 03:57AM
Well I just switched to spray can acrylic. Clear of course, cause I could not find a polyurethane coating.
I just received my autotransformer today. Its so shiny and new.
I spoke with my professor about using the manufacturing lab for my coil production and he said it was ok. So now I have an entire work shop complete with bandsaws and lathes to complete my coil. I'm giddy.
EvanLAB: My secondary took about 2 hours to wind. Once I got the technique down, the last half took about ten minutes. The advantage of the power drill is that the setup was relatively cheap, amounting to 20 dollars (if you have the drill already). It was easy to control once I got the hang of the drill trigger (and the battery wore down a bit :) )
Peace!
Seoul_lasers
Tue Aug 26 2008, 04:09AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
Tom540 wrote ...
MOT_man wrote ...
+ it dries faster!
You are very very lucky, often moisture get caught under the sec winding and can cause a flashover/shorted winding. Actually i use either Urathane varnish (crystal clear coat) (get it at a paint store) and or 2 part epoxy compound. I usually spray XMFR enamel on the windings to hold them then epoxy the secondary as I did on my last coil. I do about 3 layers on my coil. The dielectric strength is great.
1 2 3 4  last
