  • Guests: 54
New Mosfet that I have found.
MRacerxdl
Sun Aug 17 2008, 01:34AM Print
I was looking here for some things to buy, and I found a very impressive rates TO-247 Mosfet.
That is IRFP90N20D:
200V
94A
380A Pulsed
580W Heat Dissipation
Gate 30V
Datasheet:
I was thinking about using it on SSTC, but I think to switch some what 50A I need a big ass heat sink .
What about using that on SSTC's or Even DRSSTCs? I found it for US$10 each
Thanks!
Dr. SSTC
Sun Aug 17 2008, 04:31AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
Mestre Racerxdl wrote ...
That is IRFP90N20D:
200V
94A
380A Pulsed
Gate 30V
Datasheet:
Thanks!
you could probably use them to build one of steve wards smaller drsstc's smile
Tonic
Sun Aug 17 2008, 03:03PM
But 200V is a pretty low voltage, the safe input voltage would be about 100V AC, so a variac or step-down transformer is a must-have thing.
MRacerxdl
Sun Aug 17 2008, 04:26PM
Yeah, I was thinking about that too, for a DRSSTC with that mosfets that I need to use somewhat 100VDC or so.
But for SSTC's I think its a powefull mosfet.
I am impressed about the dissipation rate, that is more than some MiniBrick IGBT's.
Can I use it to switch 4kW or so with a fullbridge of that mosfets?
Sun Aug 17 2008, 10:27PM
Well, note the 580W dissipation is *only* if you can keep the case cool at 25degC. Which basically means you'll need a cold plate (liquid cooled) to do this.
From there, you derate 3.8W per degree C.
MRacerxdl
Sun Aug 17 2008, 10:56PM
Hmm, a Peltier Cell with one side a copper bar with the mosfets and other side with a big heatsink + cooler will be good for that ?
