  • Guests: 47
01/13 si2030 (62)
Help in schematic for 12- 48v bench suppy
JamesH
Sat Aug 16 2008, 05:16PM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I have spent a couple of days on the wb!
I want to build a linear power supply ( to drive fly backs etc) from the parts I have
i.e. 4 x 24 volt transformer ( identical) Volt regulators,Zeners, caps etc but no 74xx chips
So I don't want to use a comparitor /op amp circuit
I would like 10 - 48 ( possibly 96) volts at 6 amps and be able to vary the voltage and if possible the amperage.
Would some kind person help me find / suggest a suitable diagram or the principles to achieve this
The regulation does not have to be wonderful
Sat Aug 16 2008, 05:33PM
Eirik made a very nice SMPS from mostly harvested parts. It goes from 15 to 48 volt sending out a total of 15 amps and it got a over current protection.
JamesH
Sun Aug 17 2008, 08:48AM
Thanks Ace7one
I would like to build the switched mode PSu at some latter date but at the moment it is beyond my experience, knowledge and capability.
I have noticed some aspects that are useful in the circuit and now know what the mysterious GDT abbreviation means .. even if I still dont know what a gate drive transformer is or does:)
I mant to tandem the 24volt, identical transformers and achive 24 - 96 volts if I can
My original intention was to just switch the outputs out in series but that failed because i was using the rectification and voltage regulation on each 24 volt circuit
I will carry on experimenting and reading up until I succeed or some one gives me some hint asto how to control the V and A
Sun Aug 17 2008, 01:00PM
For more information about GDT. Link2
You can try the L200 from ST.
If you see the examples in the datasheet, you can add a transistor in series to achieve higher output voltage. There is also ways to increase the total current, for instance parallel them.
