  • Guests: 60
01/13 si2030 (62)
Using Transistors in Series
Firefox
Mon Aug 11 2008, 08:02AM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I have been reading up on switching power supplies and a question popped into my head that didnt seem to be answered anywhere else. I know the practice of paralleling switches is common and that transistors share current well if they are kept at even temperatures, assuming they are the same transistor. But what if you need more voltage at the same current? Can you use multiple IGBTs or MOSFETs in series to get the desired voltage, and might switching topology (hard switched PWM vs. ZVS/ZCS) make a difference in this answer?
Mon Aug 11 2008, 08:25AM
It does exist. Probably the safest route to go is ZVS switching. The reason being that you have a wider window before the collector voltage is higher than the rating of any single device.
So just like ZCS is nice for paralleling devices, ZVS is nice for seriesing them, and the reason is simply that it provides a wider window for the transitions to take place before any single device gets blasted with excessive current or voltage.
Hard switching is tough for series devices, because even nS timing can be critical. I think the schemes ive seen put TVS diodes or MOVs across each device to briefly take over if it doesnt turn on in time. Not a desirable option.
quicksilver
Mon Aug 11 2008, 01:47PM
I've wondered this very same thing....
If I understand, what you're saying is that the design would always be primary in this concept?
My original thinking was that the reason the 2N3055 drivers were such a failure was that they reduced them to one unit...(?) I had thought that the original designs using two 2N3055's brought the needed levels to the deign (via multiple units) but you're saying that would not be the case: that circuit design is primary?
Firefox
Mon Aug 11 2008, 06:27PM
Aren't ZCS and ZVS the almost the same thing? I mean, you cannot have ZCS without ZVS, because if there was a potential difference, current would want to flow (V=IR), correct?
Myke
Mon Aug 11 2008, 07:00PM
With an inductor, the current lags behind the voltage and with a capacitor, the current leads the voltage. Is this right or did I switch it?
Mon Aug 11 2008, 07:11PM
Firefox wrote ...
The problem is tha zcs is never perfectly zcs, even a little current always flows. And this is enough to force the full voltage across very high impedance switch in off state. That said, most today MOSFets even IGBTs are avalanche rated, so seriesing them should not present very big problems.
