  • Guests: 21
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
a few components needed for staccato controller
Kristian
Sat Aug 09 2008, 03:23PM Print
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
I'm putting together the staccato controller found at easternvoltageresearch.com . A few of the components listed are no longer available from digikey. I was wondering if anyone had any of these that they could part with, or suggestions for replacement parts would be great.
These are listed quantity, digikey part number, description.
2x, 2N3904-ND, Transistor, NPN
1x, 2N2222-ND, Transistor, NPN
2x, P405-ND, LED, T-1, Red
1x, 3296W-203-ND, Potentiometer, 20k, 10 Turn
1x, 3296W-503-ND, Potentiometer, 50k, 10 Turn
Sat Aug 09 2008, 05:43PM
you can get the transistors and leds cheap from this ebay shop
I just used a 22K and 47K potentiometer instead, and you can use any leds :)
Ken M.
Sun Aug 10 2008, 12:00AM
How in the world arent you able to get 2n3904s they are VERY common, the 2222's Ive always had problems with them.
Kristian
Sun Aug 10 2008, 12:33AM
Ken M. wrote ...
Digikey lists them as non stock. I just ordered them from the store that MadsKaizer recommended. I found the pots also, so it looks like I'm set.
