  • Guests: 33
Brand New HV Power Supply on Ebay
jpsmith123
Fri Aug 08 2008, 12:51AM Print
Look at this thing:
Fri Aug 08 2008, 02:01AM
Just the thing for that particle accelerator you have planned tongue
I wouldn't really trust it for pulling arcs, although I suppose with a decent series resistor it would probably hold up fine...
Coronafix
Fri Aug 08 2008, 02:36AM
It would be good for a lifter, although the current supply it a bit low.
Dr. SSTC
Fri Aug 08 2008, 03:25AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
Coronafix wrote ...
50 milliamps would be enough for a very large lifter
jpsmith123
Fri Aug 08 2008, 04:06AM
Well it seems someone got a good deal...it went for $329.00 (with only one bid). If I didn't recently buy a semi-expensive scope, I would have put a bid in on it.
Herr Zapp
Fri Aug 08 2008, 05:54AM
Doesn't this rack mount enclosure look impossibly small for an 80KV, 50ma power supply?
And, there are no HV connectors at all on the back?
Finally, doesn't it seem odd that a brand new 80KV, 50ma power supply would sell for $329, with only one bidder??
This appears to be only the "front end" control module for the actual HV power supply, which is a separate unit.
Rather useless without the "other half".
Herr Zapp
Fri Aug 08 2008, 08:48AM
Yes, as far as I know that box is just an IGBT inverter that drives a separate multiplier stack. Link2 I've seen the stack part of one of those on Ebay before, so someone may still get lucky smile
jpsmith123
Fri Aug 08 2008, 02:47PM
I think you're right - that's only the inverter part of it. Although IIRC the same seller did also recently have a 50 kv, 50 ma rack mount unit (although it might have been a different manufacturer) that did have a HV output connector on it.
