  • Guests: 31
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
Safe bridge rectifier temperatures?
aonomus
Tue Aug 05 2008, 10:58PM Print
This is a question about silicon and bridge rectifiers I suppose. Why do rectifiers rated at 35A get hot at even 4A? Also is it more optimal to operate the rectifier as cool as possible, even though high temps lie within the derating curve?
My power supply has a hefty transformer based off a LM317 and a pair of 2n3055 pass transistors, and at load of about 3A the rectifier gets hotter than the transistors (which are isolated using mica washers so they have even worse cooling). My rectifier is bolted straight into the chassis (1.2mm thick steel) with some thermal paste, and its only taking 4A peak AC input at 20V. I significantly *overrated* the rectifier (600V 35A) so I can't figure out why its generating so much heat (too hot to touch the rear of the case). Bridge/chassis temperature is 41degC approximately at 3A output load (0.8A AC load)
Tue Aug 05 2008, 11:32PM
You might find higher efficiencies if you go with a lower voltage bridge, it will typically have lower voltage drop.
In any case, 60hz rectifiers can run stupidly hot, like 100C, and be OK.
Tue Aug 05 2008, 11:50PM
yeah, lower voltage bridge is a good idea, and schottky diodes even better one since they have much lower voltage drop, but they're overkill in my opinion for an already very inefficient linear PS.
Overrating the current won't do too much really - a 10A bridge would unlikely be any noticeably hotter than your 35A one, it's just the matter of forward voltage drop and heatsinking.
For 4 amps you should have some heatsink on it, with help of forced air cooling if you have it (I think a 4 amp linear regulator should have a lot of heatsinking?) Steel chasis is poor conductor of heat, it's not doing much more than if you just left the bridge hanging in air.
aonomus
Tue Aug 05 2008, 11:59PM
Hmm, I just checked the datasheet again, its not a 600V, its a 200V rectifier.
The linear regulator itself does have a heatsink but it barely heats up at all, the output of the regulator feeds the 2n3055 bases which carry all the current, and even at 3A they don't heat much with the heatsinking. I have another heatsink handy but I have to mill it down in order to accomodate the size of the rectifier, I only bolted the rectifier to the case just to keep it out of the way and secure because I didn't expect that much heating.
Wed Aug 06 2008, 07:04PM
This makes me wonder, are you even regulating the voltage down with the transistors? The worst possible load for this type of PS would be the lowest output voltage with maximum current, meaning the transistors dissipate Vdrop*Iout. If you arent dropping hardly any voltage across your transistors, then you arent really testing this power supply for worst conditions.
Wed Aug 06 2008, 08:02PM
wrote ...
That 35A rating assumes they are being cooled to some temperature (i.e. 25degC which is shown on the datasheet)
Depending on cooling, that max. current may be considerably less, i.e. just a small heatsink. It all depends on what the junction temperature is that matters.
aonomus
Thu Aug 07 2008, 12:19AM
Steve Ward wrote ...
I took a transformer kicking around and used it as a giant inductor, 3V at 6A (fuse rating). The transistors get too hot for the heatsink size, but the rectifier doesn't get significantly hotter. Down at about 3V 3A the transistor heat is manageable.
Something deep down inside me wants to overclock this rectifier bridge with liquid nitrogen... :D
Regardless its a low duty powersupply, I don't have all too many loads that will draw many amps at the moment, half the reason why I'm having so much trouble is because I'm compelled to keep the transformer with its original casing (from an old UPS). If I made a plywood case I would have had a much higher current rating, the transistors are isolated using mica washers which reduce the effectiveness of the heatsink. With plywood I could skip the isolation step and just screw it to the wood... oh well, live and learn.
Dr. SSTC
Thu Aug 07 2008, 08:07AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
dont think that if its rated for 35amps that its actually going to heat up less it just means that it can allow more current to pass, same with transistors.
thats why on the if4007's ect you have thick leads to help with the heat sinking
Thu Aug 07 2008, 08:46AM
I would suggest measuring the current through the rectifier when you have no load connected to the PSU, as a rectifier bolted to a steel case with a smear of heat sink grease shouldn't get as hot as you describe at only a fraction of its total current rating.
If the current passing through the rectifier seems excessive when you have no load on the PSU output, you should consider the possibility that something in the smoothing and regulator circuits downstream of the rectifier is partially shorting your supply to earth.
Thu Aug 07 2008, 09:16AM
Thin sheet steel makes a really lousy heatsink. I've tried it before and it just doesn't work.
Also, rectifiers all heat up about the same, regardless of their current rating. The voltage drop across a diode doesn't change much with current or diode construction, so a 5A bridge will dissipate about the same amount of power in your circuit as a 50A one. The 50A one will be much better equipped to get rid of that heat, though, if it's properly mounted to a good heatsink.
