  • Guests: 42
Turn your tesla Coil into a giant plasma ball
Austin
Mon Aug 04 2008, 09:27PM Print
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
Just wondering if anyone has attempted encasing a Tesla coil in a giant vacuumed glass globe or something similar? wouldn't putting the chamber under pressure and filling it with some inert gas make some very impressive and continuous streamers?
Also has anyone attempted any experiments with ferrofluid and Tesla coils?
Shaun
Mon Aug 04 2008, 09:56PM
You may not even need to use a vacuum; certain gases like argon and helium are much easier to ionize than air, even at atmospheric pressure. People have done some experiments in this are. I've seen pics of them before and hopefully they will post them here.
As for ferrofluid, I don't think a TC would affect it. The magnetic field produced by a running coil is not THAT strong, and even if it was the pulses are far too short to produce a noticeable movement.
Tue Aug 05 2008, 04:48PM
Keep in mind you may want some good old atmospheric pressure air to insulate some parts of the circuit to keep it from arcing between primary and secondary coils, but on the other hand it probably would be pretty cool.
Tue Aug 05 2008, 06:27PM
Yeah, ferrofluid isn't going to do much unless its in very close proximity with the primary coil.
