  • Guests: 66
01/13 si2030 (62)
Using SCRs
Firefox
Mon Aug 04 2008, 12:02AM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I have been browsing SCRs and looking at what I need to build some wire exploders, induction launchers, and the like, but I am unable to understand how you guys pick your SCRs. It seems like more than just the current rating, which to me makes sense as the most important item when you are talking about putting energy into a near short circuit. Someone said that with 60 or 120J, a certain (dont remember which) SCR could handle it, but in a short circuit, it would have slightly exceeded the pulse current rating. So is pulse current rating the most important aspect of the SCR, or is there more to it than that?
Myke
Mon Aug 04 2008, 12:09AM
There is peak reverse voltage rating to take into consideration because there will be some high frequency ringing.
Hon1nbo
Mon Aug 04 2008, 01:00AM
also consider the voltage spike coming from the gate of the SCR to the trigger circuit (had SERIOUS problems with this)... Then there is the switching time/voltage (how long until on, and how low E until off).
Shaun
Mon Aug 04 2008, 01:58AM
Well the thing is, the most common use of SCRs by amateurs (and 4hv members) by far is in coilguns. Coilguns will have peak currents that are FAR lower than the applications you discuss (induction launchers/wire exploders) of similar energy. The pulse length will be much shorter in duration, but things still are looking bad for SCRs under those conditions.
Not saying they absolutely can't be used, its just that a 300J coilgun will require a much smaller SCR than a 300J ring launcher. An SCR also has a rather limited dI/dt (relative to a spark gap), which is bad for induction launchers where you need the current to be able to ramp up as fast as possible. Again, SCRs can be used, but once you get higher than a few hundred joules one is almost forced to switch to a spark gap.
To answer your original question, I think the most important rating is Itsm, the non-repetitive peak surge current. Keep in mind, this rating is given for a duration of 8.3ms (half a 60Hz sine pulse). 8.3 ms is quite a while, even for coilguns. So its fairly reasonable that this rating can be overshot by quite a bit before your SCR detonates. Just how far over you want to try and go is up to you...scope+current probe helps here.
rp181
Tue Aug 05 2008, 12:40AM
I talked to some engineers at a power semiconductor company, heres what they said:
All rating usually have about 10% saftey margin, also, pulse rating is for 10ms, for coil gun applications, pulses are less then 1ms. The surge rating exponentially goes up as time goes down, it is safe as long as you keep the pulse short enough for the power, and wait a couple of seconds between shots.
Tue Aug 05 2008, 01:58AM
I would look at the I^2t 'fuse' rating, since that is what will dictate wether or not you will melt the die. Also very important is the di/dt rating, since you are talking about HUGE di/it for things like ring launcher.
Firefox
Tue Aug 05 2008, 04:07AM
Ok, say I was discharging a 450V 2200uF pulse cap into a dead short with an SCR. What determines the rise time and A/us? I know the Io is determined by the voltage of the cap and resistance of the load. Is it a combination of the resistance and inductance of the load, or just the inductance?
Myke
Tue Aug 05 2008, 04:15AM
Resistance and inductance. The resistance is pretty low but it's still there. Same with inductance. Don't forget the ESR and the inductance of the cap too. Isn't there a calculator out there that calculates the max pulse current when given the resistance, capacitance, and inductance?
Firefox
Tue Aug 05 2008, 06:55AM
I'm not scared of a little paper/pencil and calculator work, so a formula (and perhaps an article/explination on this topic) would be fine too.
rp181
Tue Aug 05 2008, 04:52PM
what is di/dt?
