  • Guests: 53
Switching HV with IGBT's?
codesuidae
Wed Mar 22 2006, 03:10AM Print
codesuidae Registered Member #337 Joined: Wed Mar 22 2006, 02:52AM
Greetings,
I'm investigating the possability of switching about 15kV with IGBT's for the purpose of powering CO2 lasers.
I've seen articles about using many IGBT's in series to handle higher voltages. I'm hoping that very cheap (~$1) devices can be used for this purpose. Only small currents need to be switched but it is also necessary to run the switch at several kHz for PWM control of the laser power.
Is this idea practical?
Thanks
Desmogod
Wed Mar 22 2006, 06:29AM
I think the problems with parralleling semi's is that there can be a propogation delay between them.
i.e. 30nS delay between all of them lets one open fully before the others, letting the majority of the current through it.
I'm sure I have this wrong, or marginally correct. (Someone will give you the FULL reasons and workarounds I'm sure!)
ragnar
Wed Mar 22 2006, 08:48AM
Yup, Jim is totally wrong, not even marginally correct. He meant to say "seriesing" and "voltage" =P
TDU has worked with four hockey-puck SCRs in series... he might have some valuable words from his experience. Turn-on time is critical, but how many kHz? Can't be that hard.. =)
Isolation of the gate drive will be.. 'interesting'.
dan
Wed Mar 22 2006, 08:50AM
dan Registered Member #223 Joined: Mon Feb 20 2006, 06:42PM
It may be possible but they all need to turn on at the same time which isn't that easy. But why do you want to go through the trouble of interrupting the power on the HV side. I mean you could just interrupt the power to the HV supply to vary the power that is fed to the laser. Or even better power the tube with a rectified high frequency transformer and adjust the PWM on the drive circuitry to vary the power to the laser.
Wed Mar 22 2006, 10:14AM
If you do make a hv string of IGBTs to handle 15 kV, e.g. using 1200V IGBTs;
-you will need say 15 'stages', each stage with an IGBT and across it a 1000 V zener/tvs
(e.g. I would use 3 x 350 V tvs because I have them)
That will ensure that no single IGBT 'sees' more voltage than it should.
Then you will have to work out how to drive the gate-emitter of each;
insulating for at least 1 kV per stage.
One way is to wind 15 x 1:1 toroidal transformers, add gate and damping resistors,
put them in series and drive one IGBT from each secondary.
This way each transformer only needs 1 kV insulation/isolation, (easy)
instead of a 'master' drive transformer requiring 15 kV isolation overall.(difficult)
If the current is very small and the frequency low, you could use a CRT as a valve!
Personally I'd desparately try to work out how to do the modulation at lower voltage.
Wed Mar 22 2006, 11:32AM
I once saw a stack of series'd IGBTs designed for switching pulses at 10kV. It was about 2ft tall, the drive circuitry looked pretty complex, and the guy running it complained that it blew IGBTs fairly often. (there were neon lamps on the stack so you could see which storey the bad IGBT was on.)
For an application like this, a better way would be to build a high voltage switched-mode power supply and control the power level by PWMing the low voltage side, like a few other posters have suggested. The Thor CCPS by Marco DeNicolai (or the simplified version of it by Steve Ward) would make a great CO2 laser driver.
Is this for a CNC laser cutting application?
Wed Mar 22 2006, 12:52PM
This is actually quite common. We do it all the time, although we use MOSFETs, for grid modulators and cathode switchers on TWT tubes. Since you are not switching lots of current, then MOSFETs should be more than adequate for your application.
Marko
Wed Mar 22 2006, 01:26PM
On higher frequencies there are big problems, but it can be done. There was a trial of SSTC that would operate with higher input voltages by Steve Ward, but very soon after topology was ashamed by DRSSTCs.
For CO2 laser switching can be simply done on LV side and then voltage stepped up, you need serious ferrite transformer but it is far better idea than stacking semi's.
codesuidae
Wed Mar 22 2006, 04:05PM
It sounds like while IGBT's can handle it, they aren't necessary because I only need a very small current (on the order of a few tens of mA).
What considerations are there with driving the gate on series MOSFETs for this purpose?
How critical is getting them all turned on at the same time, and how does one go about getting that precise syncronization?
As an alternative to switching the 15kV I would consider switching the input side, but I'm don't yet know what the output requirements are. It seems that this would involve something a bit fancier than switching line AC to the primary. Is it practical to use a NST or MOT, or do I want to build a transformer from scratch? I have flyback cores from three 15" monitors that might be useful for that.
The idea is to use PWM to control the power output to allow for cutting of a variety of materials. I haven't worked with cutting lasers before, so I'm still learning the details that I'll need to know to set up a system.
My goal is to set up a CNC laser cutter on the cheap while learning about laser operation, control and optics. The project is more about learning than it is about a need for an effective machine, so that will determine how much I buy and how much I build.
Thanks for the input!
EEYORE
Wed Mar 22 2006, 04:46PM
Couldnt you just use a variac to control power in to the laser?You mentioned a NST or MOT...Go for a NST and run it off a variac.
Matt
