  • Guests: 40
Bridge PCB Sanity check
Dylan
Sun Aug 03 2008, 04:23AM Print
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
Hi all, I'm about to get a run of full bridge TO-247 PCB's made, I was hoping people could have a quick look to make sure they are sane.
They are designed to have all TO-247's mounted under the board on the one heatsink , hence the drill holes for the mounting screws (last pic is an EARLY one showing this layout).
Alternatively you could mount all TO-247's upright and have a Z shaped configuration of 2 heatsinks.
Layout is for the PCBExpress miniboard service, and fits 2 per board smile
Should be a nice board, some features :
Low inductance ( I think, I hope, comments? )
Multiple connection options , with both 3mm holes and screw terminal options.
Room for two transient suppression devices between each EC.
All holes slightly oversised for easy desoldering smile
Anyway , heres some pics:
1217737301 1024 FT0 Quickbridge All
1217737301 1024 FT0 Quickbridge Bottom
Type2 Overlay
