  • Guests: 44
Primary tank cap positioning
Dylan
Sat Aug 02 2008, 02:43PM Print
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
Is there a clear benefit to having the primary tank cap mounted close to the bridge , as seems the norm?
Or could you mount it close to the primary coil, uncluttering the bridge layout?
Mon Aug 04 2008, 02:35AM
Doesnt matter.
All that matters is the total loop inductance. Generally you should keep your off-axis (that is, un-coupled to secondary coil) inductance low, so that all of the inductance is in your primary coil, this gives the best coupling coefficient as any outside L just adds in as leakage, lowering the coupling coeff. Since its a series circuit, there is no reason to keep the leads shorter to the bridge vs the primary, it all adds up no matter where it is.
