  • Guests: 43
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Class E revisited
Sat Aug 02 2008, 04:56AM Print
So the last day or so i started to play around with the Class E circuit again, using a 1200V IGBT this time (TO-247 package). To my surprise i could push a nice 16" spark from the thing.
Right now its powered up from a 120V to 240V step up transformer (which is sagging under the load, btw). The thing has already blown a 15A house fuse, so i moved it to my 40A circuit just to be safe wink. The heatsink gets fairly warm after just a few seconds of running, i havent done much endurance testing as im still a bit surprised the thing works this well at all!
Im still working out all the details on this circuit, but its pretty much the same thing as my other class E setup, just more power and a better setup. The IGBT is a 18N120BND from fairchild. The tank capacitor is about 27nF, and the primary is 2 turns on a 6" form. The secondary Fo is 300khz with no spark loading, and drops to about 290khz with sparks going. I also put an 800V string of TVS diodes across the IGBT for some safety, it should at least give me indication that the voltage is too high if they heat up, so far they havent.
I added a series inductor (ferrite cored) with the primary with the hopes that it might tame things, which it does, but now im considering removing it, which will require retuning everything... maybe for the better. The ferrite doesn't get warm, so i dont think its doing much anyway.
Ok, well im gonna get back to playing with this thing smile.
Sat Aug 02 2008, 05:15AM
Wow, nice man! I am glad to see that you are getting back to doing more work :P.
Dr. SSTC
Sat Aug 02 2008, 05:23AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
holy cow :o
i would have never thought a Class E could produce those kind of arcs
well try audio modulation before the IGBT blows or somthing, i should be extra loud
are you using an interuppter or running CW
how much energy do you think it is using
don't forget to draw a schematic when everything is tuned
Sat Aug 02 2008, 06:41AM
Well, a little more tinkering and ive gotten rid of my series inductance with the primary. Essentially i kept the total L about the same, and lowered the coupling between primary and secondary. The IGBT C-E waveform goes from overdamped (non ZVS switching) at the start of the 60hz half-wave, to being a bit underdamped throughout most of the burst. This is of course a tuning compromise.
I also removed the 240V transformer from the circuit, and to my surprise, the coil worked just as good with a sturdy 120V input over that crappy transformer (which is bigger than a MOT, so id expect it to handle some power, but apparently not much).
And then of course, the IGBT exploded confused . From the best i could tell, the Vce peaks at about 500-600V, so it had to be overheating from either too much current or switching losses. I could see either one being the problem since 1) its a lot of power to begin with, and 2) it doesnt achieve ZVS for part of the envelope.
KresoLiubov
Sat Aug 02 2008, 06:46AM
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
I got similar results from class E SSTC with a 1200V IGBT-s. However they didn't live long
Sat Aug 02 2008, 06:56AM
Yeah, this topology is just so finicky... not sure if i want to continue messing with it or not since i dont have so much free time as before to play with stuff.
Firnagzen
Sat Aug 02 2008, 09:42AM
Firnagzen Registered Member #567 Joined: Tue Mar 06 2007, 10:55AM
Amazing sparks! If you don't mind my saying so, the whole set up looks rather... eh... 'ghetto'? Perhaps a short appeared somewhere and killed the IGBT?
Also, are you running on 1/2 wave rectified?
Sat Aug 02 2008, 11:27AM
Amazing, SSTC development has come full circle back to the single transistor flyback driver.
Mates
Sat Aug 02 2008, 12:26PM
Welcome in the club of the single switch high power coilers amazed
Remeber that the biggest advantage of single switch topology is that you can parallel the transitors very easily. Next time use two of them and your coil will survive much more ;) It is also good idea to use more TVS in parallel...
Since I'm operating quite powerfull single switch SSTC in a kind of pseudo-classE, based on BUP314 IGBT transitor I can share some experience. I'm using tl494 driver which seems to be poor choice for ClassE since there are very limited feedback possibilities. However, I can drive the system in 1/2 of the resonant frequency which lowers the demands on transitor switching speed. I can run the coil for minutes (no interrupter) and the power meter says 2.5KW wink I know your toplogy is problably much different, but maybe you could find some inspiration...
The coil details: Link2
1217679761 1025 FT51291 Classe
MRacerxdl
Sat Aug 02 2008, 04:05PM
Nice two coils! I need to try to make one of that too!
But I never think that was possible with big IGBT's.
