  • Guests: 31
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
****NEW TESLA COIL PROJECT****
Alexandre
Thu Aug 21 2008, 12:33AM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Good Day coilers..
Today I build my MOT Power Supply .. cheesey
It is composed by 4 MOTs, totaling about 9kv @ 500mA.
Still want to make a ballast for control of current ...
One thing that I will give emphasis to this source is the conection 110/220V for various environments ...
Is not ready yet, but put the photos of it being like this ... tongue
1219278265 1228 FT51236 Pict0293
1219278265 1228 FT51236 Pict0012
1219278265 1228 FT51236 Pict0014
1219278265 1228 FT51236 Pict0015
1219278265 1228 FT51236 Pict0021
1219278265 1228 FT51236 Pict0022
1219278491 1228 FT51236 Pict0023
1219278491 1228 FT51236 Pict0024
1219278491 1228 FT51236 Pict0025
I will also buy a few litres of mineral oil to isolate them.. cheesey
Alexandre
Seoul_lasers
Thu Aug 21 2008, 04:30AM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
BtW, quite a few mots are 2500V rated output... so you'll be closer to 10Kv 0.4-0.5 Amp. You going to be pulling monster flames. I once ran a 5 pack and managed a peak of 1 amp before my 30A breaker popped like a firecracker.
Fri Aug 22 2008, 05:57PM
Nice insulators, your coil is coming along good.
Alexandre
Fri Oct 03 2008, 12:57AM
Good Day Coilers....
After a long time, I finished my Tesla coil ..
I had some problems in the first test, but it solves, until the moment it about 5 foot of sparks, but I had a little problem, one of the mot of my source burned cry , so not to lose the day, modified and used only 3 mots , The result was excellent for a first test .. shades
I intend to get this source as soon as possible, with a word out, the power has dropped considerably, then want to buy a new and fast ..
Some pictures: amazed
1222995053 1228 FT51236 Pict0121
1222995053 1228 FT51236 Pict0124
1222995053 1228 FT51236 Pict0125
1222995053 1228 FT51236 Pict0128
1222995279 1228 FT51236 Pict0132
1222995279 1228 FT51236 Pict0133
Alexandre
Myke
Fri Oct 03 2008, 01:12AM
Looks good. cheesey Cool coil.
I like the power supply a lot. Especially the insulators.
Fri Oct 03 2008, 02:01AM
Great coil!! You are really good at coiling, IMO. I also really like your zvs powered tesla coil(that is you right? I am confused now that you changed your name all up..).
Coronafix
Fri Oct 03 2008, 02:17AM
Bloody good job!! Some great pics too!
Can you give us some info on your cap bank and the RSG
you are using? And did you end up ballasting your supply?
Alexandre
Fri Oct 03 2008, 09:32PM
Good Day Coilers!!
In my RSG'm using an engine with about 3450 RPM, for the coil seems incredible that it worked with the speed of the engine.
The disc was made of acrylic with 12 contacts of brass, the fixed contacts are made of pure copper ..
Some pictures of him ...
1223067469 1228 FT51236 Pict0072
1223067469 1228 FT51236 Pict98
The Cap Bank It made with the association of 40 of capacitors 100nF @ 1600V each, put 10 in series and 4 series of 10 in parallel, for a total of 40nF @ 16kV ... resistors of 10M were placed in each cap ..
1223068112 1228 FT51236 Pict0011t 3
1223068112 1228 FT51236 Pict0043
1223068112 1228 FT51236 Pict0064
and for ballast my power suplly, i use a hot water heater elements, I intend to improve this item with a Rotary Switch, with several sections, thus have a better control over the power source placed in..
And a pictures of my complet power suplly..
1223069484 1228 FT51236 Pict0134
Alexandre
Sat Oct 04 2008, 03:15AM
Very impressive! If you do not mind me asking, where did you get those mice caps? How much did they cost? They are obviously very good quality.
MRacerxdl
Sat Oct 04 2008, 02:40PM
When I went to Alexandre House I saw this caps, that are Big Ass 100nF 1600V caps, for good current capability and works good at 500kHz (They are IGBT Snubber Cap)
It costs arround R$6 here (US$3,5) but the distribuitor have a minimum quantity of 40.
Alexandre may correct me if I am wrong.
