  • Guests: 50
6.25" Tesla Coil running better with 4 X 12 kV 60mA NST - video included
MOT_man
Thu Jul 31 2008, 10:41PM Print
I just wanted to let you know that my 6" coil has been getting a little more TLC over the summer. I added yet another transformer to my PSU - and woah! I had to duck! I'm getting close to optimum performance now - I think I might have to get yet another transformer just to satisfy my curiosity. :)
Just follow the link below to see my video on youtube.
Feel free to offer any suggestions you might have. I know I need a better gap!
ENJOY!
Ultra7
Fri Aug 01 2008, 12:19AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Very cool!
The video says you are planning on doing a SRSG, correct?
MOT_man
Fri Aug 01 2008, 12:24AM
Yep! I plan to run this coil inside a demo space for an art exhibition in Oct. - SRSG would certainly improve the performance factor of the coil!
Seoul_lasers
Sat Aug 09 2008, 12:02PM
Seoul_lasers Registered Member #1630 Joined: Sat Aug 09 2008, 11:36AM
You know me MOT_man.. I helped you wind the secondary ;)
MOT_man
Wed Aug 13 2008, 04:08PM
Yet another video - shot at night with a slight breeze. Enjoy.
Alexandre
Wed Aug 13 2008, 06:35PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Very good coil!!!!!
Seoul_lasers
Fri Aug 15 2008, 12:34PM
You can easily gain some more inches by getting a smoother toroid.
One way of doing this is to use an innertube as your shape and fiberglass it. After this you can use bondo or epoxy and cover this with thick aluminum foil. This has been an proven method ... The other is by making a wire mesh using an innertube as a base. Both seem to work well. Dryer ducting works but is lossy due to the sharp points.
MOT_man
Mon Aug 18 2008, 07:11AM
Another great video of the Tesla Coil - I made some improvements by adding 2 more turns on the primary and a bigger second top load. Have a look when you get the chance.
Just click the link provided below!
ENJOY!
Seoul_lasers
Tue Aug 19 2008, 12:55PM
I certainly hope you add some more transformers so you can run this unit 240vac 30A !! I bet you will see BIGGER sparks? 360mA ---
Be aware you will have to upgrade those 100W resistors for something bigger... leave the caps.
Remember a smooth toroid will allow for a single breakout point.
MOT_man
Wed Aug 20 2008, 03:00AM
Yeah, well I'm planning on stripping the power supply down and re vamping the wiring - maybe add 2 more NSTs for shits and giggles.
12 kV @ 360mA should do nicely with a SRSG :)
