  • Guests: 56
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Sell huge Xray tube
Linas
Thu Jul 31 2008, 05:56PM Print
i have unsefull X-ray tube, wiyh rotating anode, and good hot cathode....
some pic...
1217526976 1143 FT0 P1430654
1217526976 1143 FT0 P1430655
1217526976 1143 FT0 P1430656
Does this tube is valuable ??? rolleyes
EEYORE
Thu Jul 31 2008, 06:09PM
Neato! If it works fine, Id say "yes" its valuable!
Where did you get that thing?
Matt
Linas
Thu Jul 31 2008, 06:57PM
mattrg2 wrote ...
Matt
I can't make it work by using 1,5KW SSTC, but i don't have detector, just old tv screen...(no blink in screen)
I found it between other tubes...
Hon1nbo
Thu Jul 31 2008, 07:10PM
I don't think CRT TVs respond to xrays, just charged particles...
rp181
Thu Jul 31 2008, 11:47PM
TV's make xrays, if it responded, image would suck.
Myke
Fri Aug 01 2008, 12:00AM
I'm guessing that the x-rays (if they could get through the glass) would pass right through the phosphors and keep going. I think that the glass in the front is a couple inches thick and also it's leaded.
EDIT: Aprox 3/4 of an inch from the broken TVs I have seen around. It's pretty thick. The glass at the other end is thinner though.
Hon1nbo
Fri Aug 01 2008, 12:46AM
Myke wrote ...
yeah there is like 10 pounds (may be an exaggeration, but a ridiculously big number in reality) of lead in a CRT monitor... don't think the glass is THAT thick though.
rp181
Fri Aug 01 2008, 03:08AM
inside a TV i found a cable that said "X-ray shielding" it was just looped aroun inside.
