  • Guests: 65
sstc modification
teslacoolguy
Thu Jul 31 2008, 02:24AM Print
I have built steve ward's micro sstc driver Link2 sucessfully and i was wondering if there is any way that i could modify the schematic for audio modulation. I have couple of ideas.
1) Put the audio signal into pin 5 of the 555 with in series with a 10nf or so capacitor.
2) Add a transistor on the output of the fet driver chip with the audio signal feeding into the base.
Tell me what you think about which one is better or if you have any suggestions on other ways to do it. Also do you think that if i used secondary base feedback through a current transformer would the preormance be any better?
MRacerxdl
Thu Jul 31 2008, 04:47PM
If you put the audio signal on pin 5 of 555, it wont work because its not 555 that is oscilating the coil, its the antenna, so if works, it will work with many noise on the sound, if it works.
About the second option, I dont know if it will work good, you may try.
The better option is use a PLL to modulate the audio.
Ken M.
Thu Jul 31 2008, 08:57PM
Alot of audio mods use the enable pin, that way the on time and such is controlled and the coil can still oscillate.
teslacoolguy
Fri Aug 01 2008, 12:02AM
I can try putting audio into the enable pin of the ucc37322 (in my case), now should i feed it raw audio or should it go through a transistor first?
Mike
Fri Aug 01 2008, 01:10AM
you'll definitely want to feed the enable pin a digital (square wave) Probably just make a simple Zero Voltage cross detector with a transistor.. though keep in mind it won't sound very good.
