  • Guests: 62
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
question about charging reactors
Arjan EMM
Tue Jul 29 2008, 11:01PM Print
Arjan EMM Registered Member #149 Joined: Sun Feb 12 2006, 09:11AM
I designed and built a big charging reactor for a dc sgcoil. A 50kva 3fase core with the middle leg cut out and an air gap. After some testing it turns out the reactor will probably start saturating at full power.
As a test i dumped a big cap through the reactor and measured the current on a scope. It should hold out to 7 Amps but the expected sine shape starts to bend the wrong way slightly at 4.5 amps and sky rockets around 12 amps.
Will the reactor still store all the energy and charge the primairy cap to twice the voltage or can you expect large losses ?
i find this bit of magnetics a bit hard too grasp.
Bert
Wed Jul 30 2008, 06:27PM
Bert Registered Member #118 Joined: Fri Feb 10 2006, 05:35AM
Have you tried increasing the air gap a bit? A small amount of nonlinearity should not be a problem - you'll charge up the tank cap a bit quicker, peak current will be a bit higher, but you'll still get approximately 2X Vsupply on the tank cap. However, if your charging inductor goes into hard saturation, you may develop power arcing in your spark gap, your charging choke may overheat, and your HV supply voltage may droop due from excessive loading. If you happen to be using an unballasted low impedance HV supply, you may even take out your HV rectifiers or trip the mains breaker/fuse.
Arjan EMM
Fri Aug 01 2008, 06:53AM
Very clear, thank you. With a longer air gap, the non linearity starts at a higher current as expected.
From the tests it looks like we can run it in discontinuous mode at the highest bps with just a little bit of non linearity.
So we should not run in the the problems you mentioned.
The idea is to set the airsgap shorter with a lower max bps depending on the power available to keep the peak currents at a appropriate level. (And so a better power factor)
Dr. Drone
Fri Aug 01 2008, 02:15PM
shades
Herr Zapp
Sat Aug 02 2008, 02:11AM
Arjan -
Did I read your description of the core as being removed from a 50KVA (fifty-thousand volt-amps) transformer? And its saturating at 4.5 amps? Can you provide some additional details about this core, like:
Material: (laminated silicon steel, or tape-wound?)
External dimensions: (overall height-width-length)
Physical form: (E-I core, O-core, or something else?)
It seems difficult to understand how a core capable of handling 50KVA could saturate at 4.5A.
Regards,
Herr Zapp
Arjan EMM
Sat Aug 02 2008, 11:29AM
Yes it's a core from a 3 fase 50kva transformer. Center leg is removed. We cut the core in two so you end up with two C's.
Laminated silicon steel.
The cross sectional area is 110cm2
Mangnetic length is about 200cm. outside dimensions 55x 55cm
1000 turns with 2,5mm2 in 20 sections.
I added some pictures of the whole powersupply
The reactor is standing in front of the 125kva 3 fase transformer with the fuse and relay box on the right. On the left you see a small part of the rectifier box. (black with ceramic white insulators)
In the second picture you seen more of the rectifier.
In the acrillic box sits a jennings hv relay that turns the coil on an off. It has it's own switching supply with a tranformer wound with hv wire for better galvanic isolation.
In the grey box sits a frequency inverter for the rsg and a motorized 3 fase variac to "softstart" the 125kva transformer.
1217676552 149 FT51019 Supplyreactor
1217676552 149 FT51019 Supplydiode
Sat Aug 02 2008, 11:30AM
wrote ...
Easy, with a large number of turns, such as you'd use to build a high voltage inductor. rolleyes
Herr Zapp
Mon Aug 04 2008, 06:15AM
Arjan -
What is the dimension of the air gap you are currently using?
Herr Zapp
Arjan EMM
Mon Aug 04 2008, 07:14AM
With two 2mm airgaps, so 4mm total. soft saturation seems to start around 4.5amps as in my first post. And gives around 3-4 henries.
With two 4mm gaps, 8 total, soft saturation seemes to start around 6 amps with aprox 2-2.5 henries.
Self induction was exptrapolated from the scooptrace while dumping 4800uF in it so it's not very accurate.
The numbers are not very far of from what we need so i guess we don't have a problem :)
After rectifiing we have 14kv, so we charge a 300nF tankcap two 28kv at max 600 bps.
Mon Aug 04 2008, 05:48PM
That should be satisfying! Thats like 70kW, very cool! I hope you will actually finish this project and show us your results, im sure they will be stunning no matter what.
