  • Guests: 68
safety gap adjustment
teslacoolguy
Mon Jul 28 2008, 11:26PM Print
hi. I was wondering what is the best way to accurately adjust a safety gap for a coil? Also should the center ground terminal be connected to the mains of rf ground?
Tue Jul 29 2008, 12:41AM
center terminal *is* mains ground.
i usually adjust mine to the point where it just starts conducting at full power, and then separate it just a smidge more.
Alexandre
Tue Jul 29 2008, 12:52PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
connect the trafo in safet and then close the contacts to lead, and then separating the contacts only a few mm shades
Tue Jul 29 2008, 01:06PM
I would connect just the transformer and safety gap and set it so that it just does not arc with the transformer turned on.
Andyman
Tue Jul 29 2008, 10:53PM
I have a 0-140 variac and my nst is rated for 115 input. I set my gap so it fires when I crank up the voltage to absolute max, since I never go that high, for fear of NST death.
teslacoolguy
Wed Jul 30 2008, 12:10AM
My mot bank puts out 8.8kv so i will use a 9kv nst and adjust until it stops arcing.
