  • Guests: 76
Webcam hackery
Sun Jul 27 2008, 09:40AM Print
this is clever. actually have a broken webcam (memory problem but otherwise works) here to test this on:)
-A
Dr. Shark
Sun Jul 27 2008, 01:54PM
I have seen that, and I really like the idea. And there is so much room for improvement!
For example the CD-Rom lens is about the worst you could use, since at high numerical apertures / short focal lengths, you _really_ want to use at least an achromatic doublet if you are not working with monochromatic light. Maybe a cheap microscope lens from ebay could be adapted for this purpose.
Also, hand-holding is a bit of a pain when the depth of field is something like 0.1mm, so building a simple microscope stage with an adjustable z-axis would improve matters greatly.
aonomus
Sun Jul 27 2008, 06:20PM
Ive used disposable camera lenses in reverse to turn ordinary cameras into macro cameras, same idea I suppose.
