  • Guests: 48
Carbon fibre torroid ?
Dylan
Sun Jul 27 2008, 05:42AM Print
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
Has anyone tried this?
Car inner tube, overlaid with carbon fibre?
I use a carbon fiber rod as a breakout point , then theres the carbon fiber ignition leads, its certainly conductive, should work as a top load , no ?
Would be an easy , if expensive way to get just about any size torroid.
Would look cool too!
Sun Jul 27 2008, 02:52PM
Carbon fiber although somewhat conductive, is still a poor conductor overall. Also, the carbon fibers themselves are conductive, the resin itself is not. Also, carbon fiber and the resin as it heats up will burn quite easily and possibly put out toxic fumes (from the resin).
I personally think it would be a poor choice.
A car inner tube overlaid with aluminum tape or foil would work just as well as a spun aluminum toroid.
Ultra7
Sun Jul 27 2008, 04:16PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
TDU (TeslaDownUnder) uses an inner tube covered in chicken wire, and he gets some pretty sick sparks with it.
