  • Guests: 41
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Extracting Latex from Ammonia
Dragon64
Fri Jul 25 2008, 05:33PM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Today, I bought a Mold Builder for making negetive mold of my body.
When I opened the Mold Builder, I realized that the Mold Builder's latex had 50% Ammonia.
Does anyone know, how I can seperate the latex from ammonia?
cbfull
Fri Jul 25 2008, 07:18PM
I think you mean how do I extract the ammonia from the latex. Ammonia is a gas, it will leave on it's own if left open to atmosphere.
In your case I think that the ammonia is required to keep the latex from curing. If you remove it or let it out, your latex will turn solid.
If you want to make a body mold you should use something non-toxic like sodium alginate, which is the stuff the dentist puts in those metal trays when they want an impression of your teeth. Aliginate is considered to be a type of latex but no one calls it that because "latex" is more of a trade name for something specific. It may even be a trademark name like "plexiglas".
Do a Google search and you should be able to find a tub of it online, and you might be surprised to find it in some health food store or pharmacy near your house.
Sodium alginate is a powder and you must add a specific amount of water to make a paste, which then solidifies after a few minutes.
Marko
Fri Jul 25 2008, 11:15PM
Hi,
hydraliskdragon wrote ...
looking at how this is used Link2 I'm a bit confused, could you explain what exactly do you want to accomplish?
You want to cast your whole body or a part of it?
Are you sure overall ammonia content is 50%, or that means something else?
The product doesn't actually appear to be 'rated' for use on human body, but liquid latex anyway used to create masks and I can't see why would it be too harmful.
One of bigger problems I can imagine is that if you use it on your body, I'm afraid latex is going to take most of your body hair as well!
Guessing shaving off the hair is not an option you'll either have to watch where you are using the stuff or wear something to protect you from direct skin contact with liquid latex. Maybe just kitchen PE foil would work?
Meh, only the specific type of stretchy natural rubber is called latex as far as I know. The dentist molding stuff might work but I fear larger amount of it will be expensive according to this site: Link2
Marko
aonomus
Sat Jul 26 2008, 05:59AM
From the minimal bit I learned watching mythbusters, the way they do it is to cast a mold using alginate, followed by plaster, they then take the alginate/plaster mold and fill it with another material, then replace the alginate with silicone.
Note that alginate won't be stable 'forever', I believe only on the scale of hours at most, so you'll have to replace the alginate with something else somewhat quickly.
Dragon64
Sat Jul 26 2008, 03:09PM
I am not actually very sure, how much ammonia is mixed in with the latex.
Im trying to make moulds of various parts of my body for ballistics and other things.
I was looking to buying alginate but Calgary doesnt seem to sell alginate.
Also for ammonia, is direct contact on skin for a prolong time cause any significant risk? 10% 20% 40% 60%
Marko
Sat Jul 26 2008, 03:32PM
According to wikipedia, Link2 solutions over 5% ammonia are skin irritants, but I honestly disbelieve this stuff contains that much.
They use it widely for face masks and body paints, I'm unsure if this moulding latex is especially different in any case.
Any potential hazards should be imprnted on the package.
You can try it on a small portion of your skin to see if it irritates, and to see how much hair will it pull off.
Marko
aonomus
Sat Jul 26 2008, 04:11PM
50% ammonia is likely a hell of an irritant.... any latex applied thick enough to make a mould will probably contain enough ammonia to cause a burn or something...
Bored Chemist
Sat Jul 26 2008, 04:35PM
Since a ssturated solution of ammonia is only about 35% this story doesn't make sense. If they have got that wrong why should you trust them about anything else?
ConKbot of Doom
Mon Jul 28 2008, 11:10PM
Marko wrote ...
Marko
but who says that its the same kind of latex, there are a lot of various kinds of CA glue, some meant for use on people/wounds, most not. I wouldnt be putting any over a large portion of your body unless its says its safe. Now a hand or a foot, I might give it a try if it didnt reek of ammonia, but still would work with it some on something else first to get an idea of what goes on with it.
