  • Guests: 50
Doubler for Tesla Coil???
Alexandre
Fri Jul 25 2008, 01:01AM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I am building a doubler for my tesla coil, and decided then that scheme of Greg:
some doubts:
Those resistors in there, R, may be just 100ohm 50W?
Dr. SSTC
Sat Jul 26 2008, 08:43AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
i dont under stand your question, if you mean will it have enough heat dissapation it probably will
Myke
Sat Jul 26 2008, 08:59AM
Yeah, I think that might be fine because most of the power from the MOTs would be dissipated elsewhere in the TC. maybe?
MRacerxdl
Sat Jul 26 2008, 10:30AM
When I was talking to tesla brasil I say it might work, but I dont know if 100 Ohms resistor arent too low for that application, most cases use a few K resistors. The big problem is to know if it will not discharge the arcs fast (making a good and smooth arc on the output), with a NST as a Charge Choke is working fine here for me, but he is winding the choke and if doesnt work, it will get some 100 Ohm 100W resistors.
Acording ohm law:
In that schematic it will drop the voltage to 194V on the out when short out with the two resistors. The two resistors have an series resistence of 200 Ohms, so it will dissipate 188W of heat, with 100W each resistor will get 94W.
But that is with the power supply shorted, I dont know if its the correct way to calc it. Correct if I am wrong.
Cain
Sun Jul 27 2008, 12:18PM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
Link2 to answer your question yes i have had mine running for quite awhile now
Alexandre
Sun Jul 27 2008, 03:24PM
Hey Cain, you are using the circuit of Greg?
Resistors is 100ohm 100W?
After the resistors you use two common filters, or is a choke??
Kristian
Sun Jul 27 2008, 04:53PM
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
I have used that same doubler circuit with two 1000W mots. I used a complete "Terry filter" Link2 instead of the 100ohm 50W resistors.
Alexandre
Sun Jul 27 2008, 04:56PM
mmmmmmmmm
god information!!!
