  • Guests: 76
Would splitting your primary tank cap work...?
Dylan
Fri Jul 25 2008, 12:04AM Print
Dylan Registered Member #1024 Joined: Sun Sept 23 2007, 10:56AM
I'm wondering , in a full bridge configuration, would this work, or have I been smoking the wrong stuff again?
Instead of having a primary tank like:
FB1---Tank MMC Cap---Primary coil---FB2
Split the tank cap in 2 and have:
FB1---1/2 Tank MMC Cap---Primary coil---1/2 Tank MMC Cap---FB2
I ask mainly because it would tidy up my bridge layout a lot.
Fri Jul 25 2008, 02:52AM
yes, that would work fine.
Andyman
Fri Jul 25 2008, 08:31PM
Thats called an equi-drive configuration and is perfectly functional. If I remember correctly, that's actually the way Tesla preferred his setup. I've also heard that using that config allows a more pure ring-down of the primary circuit.
Dylan
Sat Jul 26 2008, 12:08AM
Excellent, thanks people.
Will post expressPCB files when I'm done.
Will be a nice, symetrical, hopefully low inductance TO-3P fullbridge layout.
Sat Jul 26 2008, 05:05AM
FYI, Kirchoff's current law says it doesn't matter what order the L's and C's are in... in fact you could break your primary into multiple segments with capacitors in series with them (provided the mutual coupling between windings was not effected). All that matters is that to total ESL and ESC (did i just make that up? equivalent series capacitance) are the same as the lumped model where you have just 1 L and 1 C.
I never understood this BS about equidrive giving some sort of advantage. I have yet to hear a credible explanation, other than "Tesla said so".
Mathias
Sat Jul 26 2008, 10:44AM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
Would this configuration work in a drsstc ? But i think as steve pointed out , it should not give any sort of advantage.
Maybe it would just ad more to total ESL cause of additional wires :P
Marko
Sat Jul 26 2008, 03:11PM
Steve Ward wrote ...
Meh, the only advantage I could ever see is that you would block DC from the primary and thus reduce the shock hazard from it... still that would be a poor excuse for touching the primary in any case.
If it's easy to do I'd go for it, as there's nothing to lose in any case.
Sometimes I'd prefer it (if I have 2 DC blocking caps of 250V, I'd rather put each of them onto other H bridge leg than both in series on one leg. )
Marko
GeordieBoy
Sat Jul 26 2008, 07:39PM
>...the only advantage I could ever see is that you would block DC from the primary and thus reduce the shock hazard from it... still that would be a poor excuse for touching the primary in any case.
Blocking DC from getting off the primary could actually create a shock hazard if charge remains in the two equi-drive capacitors at the end of a run - Always use bleeder resistors!
