  • Guests: 55
DRSSTC confusion
KresoLiubov
Thu Jul 24 2008, 04:41AM Print
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
I'm using a half bridge for my DRSSTC. The reference schematics is from eastern voltage research.
I'm not using a voltage doubler since we use 240 V lines here. Where should i connect the end of primary marked in red circle:
1. + or - on main bus cap
2. Neutral wire of 240 VAC
1216874503 1153 FT0 Half
Thu Jul 24 2008, 04:52AM
Kreso,
The confusion is because dan uses a voltage doubler where the lytic center point connection is also line neutral. There is no reason in particular to connect the primary to the center point of the 2 caps, the + or - rail works just fine as well.
Do NOT connect the primary back to the AC power input, that would be very bad.
KresoLiubov
Thu Jul 24 2008, 05:29AM
Steve Ward wrote ...
Kreso,
I thought like this and after you confirmed me i was sure. But Dan said other way
