  • Guests: 54
Bipolar TC
Coronafix
Tue Mar 21 2006, 02:08AM Print
Does anyone have any links to some horizontal bipolar coils that people have made?
The one I was trying to find but doesn't seem to exist anymore is Dave Huffman's plans.
I wondered if the exact placement of the primary coil is vital, for instance using a flat wound
coil would be more difficult to adjust than a helical.
Tue Mar 21 2006, 02:53AM
You actually mean half-wave coil. The primary doesn't have to be exactly centered, however solenoid wound coils are usually the norm for these types of coils.
Also, you will need to put an RF ground on the middle of the secondary if you want a little play in the position of the primary. This will ensure maximum voltage nodes at each end of the secondary (half-wave). However, if you can ensure the primary is exactly centered on the secondary, you can do away with the RF ground.
I've done it both ways, using a solid state primary driver, as opposed to classical spark gap front end.
Coronafix
Tue Mar 21 2006, 10:50AM
Yes, a 1/2 wave coil. Does this mean that the tank frequency will have to be twice that of a 1/4 wave coil of the same size?
I want to know if it is possible to make a small 1/2 wave SGTC, with a, say 12-16" long secondary. I have not seen any examples of a 1/2 wave coil this small.
Tue Mar 21 2006, 12:38PM
You can make it as smal as you want.
Here is my small bipolar SGTC
http://www.geocities.com/l_vasiliu/bipolar.html
Using plastic ties, the coils can be centered very well.
I had to use a bigger primary form though, to eliminate the breakdown between pri and sec coils.
Coronafix
Wed Mar 22 2006, 01:13AM
Thanks Vasil, that was just the example I was looking for. I had only seen large ones like this arcane looking specimen.
I like your site, you have a lot of nice MOT designs.
colin heath
Fri Mar 24 2006, 01:14PM
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
Hi,
Heres a pic of my spark gap bipolar coil. driven by 2 parallel 4kv 8ma transformers. brass spheres are door knobs and the box it's in is an asda bread bin! where else can you get a beach wood box for £9 amazed
cheers
colin
1143206043 123 FT5038 Bipolar Tesla Coil
1143206043 123 FT5038 Bipolar Coil Internal
Dr. Drone
Fri Mar 24 2006, 05:35PM
shades
Hazmatt_(The Underdog)
Sat Mar 25 2006, 05:39AM
That's awsome
Sat Mar 25 2006, 06:32AM
Nice coil Colin, very well made!
Coronafix
Mon Mar 27 2006, 01:49AM
Very nice Colin. Can you give me some specs on it? What size xformer, caps used, size of secondary, etc.
I love the portability of it. Are they ballasts under the spark gap?
