  • Guests: 49
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
ZVS flyback driver parts list??
Plasmaarc452
Sun Jul 20 2008, 11:31PM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
Alright, I am going to build the ZVS flyback driver but I am worried that I am going to order the wrong parts from mouser. (It has happened many times)
I may be asking for a lot but could someone that has built this please post the part numbers of each component?
I prefer MOUSER, but DIGIKEY is alright.
Any help would be greatly appreciated.
Ken M.
Mon Jul 21 2008, 01:27AM
Vendor wise I usually go with digikey because they are less costly, but if more then half your parts are either cheaper or only available threw mouser then go with them.
Plasmaarc452
Mon Jul 21 2008, 01:32AM
Mouser is cheaper for small orders because of shipping.
Plasmaarc452
Mon Jul 21 2008, 04:19AM
Alright, I made a parts list but I need to be absolutely sure that this is correct. EVERY PART # IS FOR MOUSER!!!!!!
Part---------- Part #-----------Quantity
1. Mosfet's------ IRFP250PBF-------------- 2
2. Zener Diodes------ 1N5349BG--------------- 2
3. FRED Diodes------ HFA15TB60PBF ---------- 2
4. 470 Ohm 2W Resistors------ 282-470-RC----------- 2
5. 10k 2W Resistors------ 282-10K-RC----------- 2
6. 1uf 100v Bipolar Capacitor------ 140-NPAL100V1.0-RC------------ 1
7. 47UH 10.7A Inductor------- 2309-V-RC----------- 1
I COULD NOT FIND ANY .68UF 250V BIPOLAR CAPACITORS SO WILL 100V AT 1UF WORK????
teslacoolguy
Mon Jul 21 2008, 04:41AM
Plasmaarc452 wrote ...
No that will not work, Use Link2
Plasmaarc452
Mon Jul 21 2008, 04:58AM
Thanks a lot, but all of the other parts are ok right?
Plasmaarc452
Mon Jul 21 2008, 05:07AM
Here is a much better parts list that I put into a table.
1216616844 1394 FT50359 Flyback Parts List
teslacoolguy
Mon Jul 21 2008, 09:12PM
You are probably going to need a bigger inductor. Also just a note... the mods dont like double posting ill
Alex M
Tue Oct 11 2011, 01:53AM
I know this thread is ancient but in-case anyone is reading I used that exact same inductor and it works fine for my ZVS.
