  • Guests: 40
DRSSTC
MRacerxdl
Sun Jul 20 2008, 05:34PM Print
Hi all, I setup all my DRSSTC Stuff here, and I get some results but not good.
I have try two Bridge Setups:
Link2 - First
Link2 - Second
I dont know what bridge schematic is correct for H-Bridge but I get the same result of the two ones.
My CT is 1:25 Turns, and I running the GDT Driver that Steve Ward used on SSTC-2 (Full Bridge)
The driver is working fine with IGBT's, I runned a flyback and I get some 5cm sparks with 55V amazed
But when I put TC on the schematic to run, it only get a 1cm spark to air (without a topload, with a topload I get nothing).
Any Ideas?
My Full Circuit:
Link2 * C1 is not 1nF is 100nF (Changed Schematic)
My Secondary Coil:
Link2 (fres 180kHz~ - 64cm x 4'', wire 30AWG)
Thanks!
MRacerxdl
Sun Jul 20 2008, 09:41PM
Working now! Thanks for 4hv IRC channel :D
Here are some result running at 150VDC:
Coronafix
Sun Jul 20 2008, 10:43PM
Nice one!! That looks hot, how many amps are you pulling?
Ken M.
Mon Jul 21 2008, 01:30AM
Nice work, however I'm a bit learly as to wether this is a DR or just a CW SSTC, considering, are you making your Primary resonate or just your secondary, and also your streamers look like cw mode which doesn't work too well for DrSSTC's.
MRacerxdl
Mon Jul 21 2008, 02:25AM
I made a DR, my primary and secondary is ressoanting.
For that sparks its pulling 10A :P
The sparks are at that form because the frequency of interrupter are too high (8kHz)
I only have one thing that is wrong, I need to use both antenna and CT to have a good output, if I use only antenna or only CT it doesnt work. Someone have any idea?
MRacerxdl
Mon Jul 21 2008, 05:56AM
Double Post, I know but:
Some videos of the result:
Link2 (Running at ~8Khz Interrupter)
Link2 (Mp3 Audio Modulated Interrupter)
Link2 (MOD Audio Modulated Interrupter)
