  • Guests: 36
Jyardana (41)
Gunboat (72)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
Simple 555 driven class E sstc.
Sat Jul 19 2008, 03:38AM Print
I did not have the stuff for a proper sstc so i decided to make one with a 555. I get about 2 inch really hot sparks with 44 volts input. It will light a florescent tube qite bright from 2 feet away. It will make plasma inside of a light bulb as well.
This is the schematic: Link2
I know that it is hard to see because i am not good at drawing schematics and because i had to take a picture of it with my camera which made a black line horizontal across the screen. And i know there is a LOT to be improved upon on the sstc, but i am a beginner with sstc's and i am fairly happy and proud about it. I might upload a video in a few weeks because i need some more irfp460's cause i just burnt my last ones :(.
UPDATE: Fixed the circuit.
ANOTHER UPDATE: Took a better picture. This one you can actually see..
Dr. SSTC
Sat Jul 19 2008, 04:38AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
it would also help if a bd139/bd140 combo was added
Sat Jul 19 2008, 04:48AM
jovica93 wrote ...
Cool... I just need to get some :(. I will not work on this for long as i am getting a new vacuum tube and this one will actually look half way decent... 25 INCH SPARKS BABY!
Oh yea, i also forgot to say i used an irfp460 mosfet, not whatever it said on the circuit.
Dr. SSTC
Sat Jul 19 2008, 07:12AM
i was just thinking could you power this type of coil from rectified mains by using a gdt
Mathias
Sat Jul 19 2008, 12:23PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
Arcstarter wrote ...
... and because i had to take a picture of it with my camera which made a black line horizontal across the screen.
by the way there is "prt scr" button ... press it and try to "paste" in paint
Shaun
Sat Jul 19 2008, 02:20PM
This is not Class E. For Class E operation you need to add a resonant capacitor D-S on your FET. It will significantly improve performance if you do, tho.
Ultra7
Sat Jul 19 2008, 04:28PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
I wonder if you have express PCB?
Express PCB will do all the manufacturing for you, but it is kind of expensive.
So I say go with Eagle.
They have wonderful Schematic programs.
With eagle, it will even help you translate the schematic to the PCB when you think you have it right.
If your Eagle stuff is ready to send into production, the guys at batch PCB will make your board for you for $2.50 a square inch.
But really, I was just showing you these so you can have a nice Schematic Diagram program.
Experimentonomen
Sat Jul 19 2008, 05:13PM
In circuitmaker you can export as bmp, just goto export and choose device dependent bitmap, then save bmp, go into paint and convert it to png, then toss it up in the thread.
Sat Jul 19 2008, 07:32PM
There is the schematic... Also, i think i will try that eagle schematic maker thing. Also, is that schematic not class E? I have a capacitor going from drain to source. It does really improve performance, hotter arcs and better breakout.
Also, i forgot to tell the primary and secondary specs. It is a 4 inch by 16 inch secondary with 28 gauge wire, the primary is something like 28 turns.
1216495946 1225 FT50211 555 Sstc Driver
