  • Guests: 75
01/13 si2030 (62)
custom flyback!!! Where to buy? Please help!
baleworker
Fri Jul 18 2008, 08:54PM Print
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
Hello everybody!
I am looking for a powerful 500-1500W flybacks, at least twice the size of a regular TV ones.
Does anyone know where to get them? Or any place who can make one for me?
Thought of winding it myself but could not even find any flyback parts, like bobbins or ferrite cores. Also there is no design info on high voltage flybacks.
I have a sample transformer taken out of an Asian laser power supply and need something similar but with different step up ratio, somebody must be selling them!
Output should provide 10-12kV DC at no load, 150ma max load current
Please help!!!
Fri Jul 18 2008, 10:41PM
Getting a ferrite core good for 1.5kw is easy, but insulating it to be able to stand up to 10+kv won't be.
I wound one a few years back, that was good for a KW or two (see second post). But I had major corona between the primary/secondary (not even 1/8" of plastic would stop it) and my primary was not happy with all of the reactive power associated with a mazzilli flyback driver. If you used a core with a larger window it should be possible to solve both of those problems.
I would offer to wind you some, but I just lacerated the crap out of my thumb so I am going to be out of the coil winding business for a few weeks angry
baleworker
Sat Jul 19 2008, 12:15AM
Thanks tons!
I almost lost hope, many profs were telling me its beyond their process capabilities. Now I am back on the road.
Speaking of a Chinese PS I have, it outputs 24kV at 30mA. Over 700W !!! The diode or voltage doubler is integrated into the transformer.
I found the core they use: Link2 it is UYF18A. Everything is enclosed into a nice plastic molding. No arcing/corona. I wish I could find the molding and bobbin as well. Then I could experiment with wounding. As you can see the core is very small, I cant believe they could insulate it up to 25KV!
Attached is the pic of the transformer I have.
Anyone knows where I can get those bobbins/enclosures? Any good websites on flyback construction/design techniques? Do you guys use machines to wound them?
I am fairly new to it and dont wanna step on the mines.
Thanks again,
Any input is highly appreciated!
1216426195 1596 FT50176 Img 3558
Andyman
Sat Jul 19 2008, 01:52AM
The "enclosure" is mostly potting. After the coil is wound, they are potted in epoxy. Of course what you see is the plastic casing that the potting was poured into, but I doubt you can purchase those.
To get a suitable bobbin, just find some plastic tube that fits over the core and wind on that. Or get a sheet of plastic and wrap it around the core and tape it to the right diameter. Take it off and then start winding.
Sat Jul 19 2008, 05:01AM
You can make your own with about 100 turn secondary and about 5-10 turn primary. Just get the core of a flyback transformer(the bigger,the better) and get either a piece of pvc pipe that fits securely over the core or what i did was got a $1 thing of polymer clay and put it over the core. I then baked it to make it hard in a stove at 200 something degrees for 20 minutes. I wound one layer of 28 gauge wire and used my 555 flyback driver at 50 volts and it would give out pretty high current at what looked like my 6kv nst's voltage. You could get some transparencies and wrap some around that first layer and then wind another layer, or maybe even more. Idk how it works so well, i guess by inductive action. I ran it at a little bit above audible freq.
Sat Jul 19 2008, 07:25AM
You can wind one yourself, it is easy. You should keep at least 2kV/mm air insulation everywhere (so if your output is 10kV, you need to make at least 5mm gap between secondary and core/primary) And if you have problems you can always put it in oil.
I wound a transformer on a regular flyback core which did output ~20-30kV without large corona problems, you can use transparent sheets as interwinding insulation and use around 50 turns per layer.
Sat Jul 19 2008, 01:07PM
Contact D.C. Cox at Resonance Research. (Just go to website)
He has lots of these he sells for $25.00 each.
Sat Jul 19 2008, 01:37PM
Dr. GigaVolt wrote ...
$25 that is pretty cheap, I would get one but i guess shipping to europe would be just as much...
Do you know how much kW ( tongue ) can they take?
Sat Jul 19 2008, 09:46PM
Actually, its $45.00, not $25.00. Anyways, here are the specs. This was from awhile ago, so i'm not sure if he still has them available, but i'm guessing he does.
The large flyback transformers have the following specs:
Overall dimensions: 5 in. x 3.5 in.
Sec. coil: 2.375 in. dia.
16 turn primary c.t. with 16 AWG wire
Special HF RF core material with 5/8 in. x 1/2 in. cross section of core
Unit operates very smooth at 120 watts continuous and up to 300 w. for short
duty cycles
Rectified 32 kV DC output and over 60 kV with doubler circuit
Units available for $45 and $6.85 for s/h
wrote ...
BTW, a regulator TV flyback puts out very little power - about 15W typically. A 500W to 1500W flyback transformer would be absolutely huge, probably about 100 times the size of a regular TV flyback. You're not going to find anything like that off the shelf.
Sun Jul 20 2008, 04:03PM
Not really, most will run at least 150W continuously, the older "bare wire" ones are often happy with 200 watts or more. I ran one modern potted flyback at 600 watts, it was smoking hot after 20 seconds but it survived tongue (the ark was 20cm long)
To OP: you could get 10 similar units (check ebay etc.) for 1.5kW of power into an arc (remember thats much more reactive power).
