  • Guests: 53
NST connection...
Nicko
Fri Jul 18 2008, 04:07PM Print
I have an NIB 8/35 Ricci NST with no GFI.
It has two earth connections, one labelled "E" and the other with the usual "Earth" schematic symbol. The diagram on the NST show the secondary being centre-tapped and connected to the core, which is connected to the earth connection (which ever one that may be - I've not used a DVM on it yet).
What is the relevance of the two earth-like connections, and is this NST suitable for a TC?
Thanks
Nick
Fri Jul 18 2008, 08:57PM
The "E" and "Earth" are the two terminals that the GFI unit would have used to sense earth leakage current, if it was there. It's not, so just connect them together.
Yes, it will probably work fine for a Tesla coil.
