  • Guests: 39
Corona Discharge vs. Coatings of Insulating Varnish on the Secondary
Dr. Drone
Thu Jul 17 2008, 02:03AM Print
shades
Thu Jul 17 2008, 04:51AM
Great article, it confirms what most of us would know, but too impatient to achieve :)
My first coil had this exact same corona skirt, and it had 5 layers of varnish. (see attached photo)
The coil I am working on know is a small audio sstc, the secondary have gotten 4 layers of ship varnish applied with a paint brush. Its not quality work as the surface of the varnish is uneven and have small ripples at certain places, I suspect it to be too thick layers of varnish applied at a time.
I sure will find the time and patience to do a good varnish job on the secondaries for my upcoming vttc and sgtc.
Now we already are talking about varnish,
do you recommend spray or brushing?
few thick layers or many thin?
how often should I sand it down, and what is the best method of getting an even surface when sanding?
1216270272 1403 FT50050 Coronaskirt
Dr. Drone
Thu Jul 17 2008, 06:39AM
shades
Tom540
Thu Jul 17 2008, 02:53PM
Tom540 Banned on 3/17/2009.
Or, if you don't want to spend your life sanding and recoating and drying. Get some glaze coat furniture epoxy. link Link2
It works great. Mix equal parts, scoop it on with a business card and rotate it while drying. In the weather we have here it dry to the touch in a few hours and fully cures in 72. It is equal to 60 coats of varnish but is much more durable. No sanding required. One coat and you're done. A little goes a long way as well.
Dr. Drone
Thu Jul 17 2008, 04:03PM
shades
Thu Jul 17 2008, 07:14PM
Dr. Spark wrote ...
Henry wrote up this website and thought it would be a great article to post.
Very interesting indeed.
This coil was in the last three W.W.T.'s and kicks butt, but now 6 more inches added in spark with just recoating the secondary.
Happy reading.
Rgs,
Ch
Actually, thats a bit misleading. According to the article 6 more inches were added because the 1" spacer was removed from the secondary and coupling was increased between primary and secondary.
Sure, the increased insulation reduced corona which decreased "racing sparks" and allowed you to increase coupling, but effectively, it was the increase in coupling that gave you better performance.
wrote ...
Your coil is a CW type coil which already has a very high coefficient of coupling. You aren't going to get any noticeable performance increase with this type of coil regardless of how many coats of varnish
you put on it.
Coronafix
Thu Jul 17 2008, 08:26PM
What this adds up to is that by increasing the insulation you are able to increase coupling thereby getting better performance,
exactly like in the case of immersing the secondary of a magnifier in oil.
Recently, I also spent about three weeks coating my new 6" secondary, and just to look at it makes it worth while.
It has a beautiful sheen. Thanks Chris for sharing.
Dr. Drone
Thu Jul 17 2008, 10:04PM
shades
Fri Jul 18 2008, 02:19AM
Chris,
I'm not sure why you think every post that doesn't necessarily agree with your statements is a personal attack on yourself. I am merely pointing out that your original statement, "...but now 6 more inches added in spark with just recoating the secondary" is somewhat misleading as it leads the reader to believe that simply recoating the secondary magically added 6 more inches, when in fact, it was the fact of increasing coupling that gave you the performance burst, which yes, better insulation of the secondary allowed you to do this as you stated.
Please stop taking every post so personally. That is certainly not my intent and should not be taken as such.
We are all in this hobby together so there is no need to start a pissing match everytime someone doesn't necessarily agree with you.
[MOD EDIT: Removed an accidental double post by myself]
Dr. Drone
Fri Jul 18 2008, 02:54AM
shades
