  • Guests: 66
Multi-kVA systems: SRSG vs DC-ARSG
Kizmo
Sun Jul 13 2008, 08:33PM Print
Finally i got time to build larger spark gap device. What sort of sparkgap design i should choose when my tank capacitor is now 75nF and it will be updated to +150nF soon and i will be using power levels between 3 to 8kVA. I can easily build any kind of rotary gap but what would you do?
Shaun
Sun Jul 13 2008, 08:53PM
Well if you can easily build any type of rotary gap I would say go SRSG, since then you dont have to mess with huge inductors and large HV diodes, you just build a regular SGTC, connect the rotary gap, and go.
An SRSG, from what I understand, is much tougher to build because you have to FIND a synchronous motor that big, and get the phasing right, but since that aspect doesn't matter to you, SRSG will enable the rest of the system to be simpler.
But DC-RSG does let you easily vary power levels via break rate...
Kizmo
Sun Jul 13 2008, 09:13PM
Regular SRSG has been in my mind for a while. AFAIK running @ 100bps (50Hz system..) can be tricky but it will give nice results when working correctly. How do you tune these things to match phase?
Shaun
Sun Jul 13 2008, 10:59PM
IIRC they are tuned into phase with the 50Hz mains by rotating the body of the actual motor! I guess its easier than repositioning the electrodes...
Marko
Sun Jul 13 2008, 11:38PM
Hi guys, to my current understanding...
Kizmo wrote ...
A mains triggered stroboscope is required to see and accurately adjust phasing of SRSG rotor.
IIRC some people have used iron-ballast fluorescent lights, which can produce stroboscopic effect due to their 100Hz modulated output, but due to sine envelope of the waveform view is blurred, and there is a phase shift caused by ballast inductance so output isn't really in phase with mains voltage.
Stroboscope probably shouldn't be too hard to build though (you can even go with LED's instead of xenon flash lamps, especially if you have some of those flash-led's from cell phones).
tesla500
Mon Jul 14 2008, 06:53AM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
I've adjusted phasing on a RSGs by scoping the primary of the pole pig powering the coil (after the ballast). The voltage on the primary is a good reproduction of the capacitor voltage, and allows you to see when the gap fires. You can adjust the phasing to get it to fire at the peaks of the waveform, or to make a 240/200bps gap fire with the same peak voltage on each firing.
If you have a stroboscope, that only tells you what your phasing is. You still need to determine what it should be, and it's not something simple like 0 or 90 degrees. The ideal phasing changes with ballast inductance and tank capacitance, so if you vary power to the coil with a variable inductor (like the current control on an arc welder), you may need to come up with a compromise. I found that setting phasing to be optimum at maximum power works OK over the whole power range when using a variable inductance ballast.
Using a variac to vary the coil's power gets around this, as the inductance and capacitance don't change with voltage.
David
GeordieBoy
Mon Jul 14 2008, 02:22PM
I have also done this with good results. It is an excellent method to look at the HV waveform across the RSG and adjust phasing without having to connect directly to the HV circuit. It also gives you a good insight into the voltages that your tank cap, pole pig and RSG are actually seeing with resonant charging.
-Richie,
Kizmo
Fri Jul 18 2008, 04:21PM
So.. it will be SRSG
Now i need to make 100, 200 and 400bps discs :)
1216398081 599 FT49833 Roottori
GeordieBoy
Fri Jul 18 2008, 04:36PM
Wow! you've removed quite a lot of material off that rotor!!! I hope it doesn't run too hot or loose too much torque.
Kizmo
Fri Jul 18 2008, 04:56PM
It has been running for few hours now and no problems so far :)
It was 3/4hp 1450r/min motor with quite many 'dead poles' and now its beatifully synchronizing @ 50Hz @ 1500r/min (runs VERY smoothly)
