  • Guests: 64
01/13 si2030 (62)
Noob Needs starting project suggestions
cannon_fodder_001
Sun Jul 13 2008, 04:51PM Print
cannon_fodder_001 Registered Member #1587 Joined: Sun Jul 13 2008, 04:37PM
I am new to the world of high voltage but not new to theory and computer technology. With those two things in mind can some people suggest to me some startup projects in which i build circuites to understand practically. My final goal would be to build and create some of the higer end devices. Oh and please tell me the TOOLS that all electroheads should have. Thanks...
Hazmatt_(The Underdog)
Sun Jul 13 2008, 06:42PM
Build a Flyback driver.
You'll need a soldering iron and a DMM. Anything else is up to you.
Ultra7
Sun Jul 13 2008, 06:48PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
I guess we all start out somewhere.
I would say for ease of project and maximum return, build a flyback driver.
Flybacks are as easy to get as finding a busted monitor/tv set and pulling it out.
What everyone should have as far as tools?
A breadboard.
I'd say at least you should have a Soldering Iron/station with a de-solder pump and some solder wick.
Also basic hand tools, Screw drivers, drills, sawsall, you know. . .
From there, a couple of 2 dollar multimeters from Harbor freight tools.
That add says 4.99, but if you go up there, you can get them for 1.99. I get like three of them at a time, since I'm likely to blow them up.
If I don't, they make great stocking stuffers.
For parts, remember that TV set you took apart, well it has bunches and bunches of spare parts, as do microwave ovens.
Eventually tho, you'll want to get more gear and tools.
I'd get a cheap oscilloscope, an LCR meter, a variac, a function generator, and probably a recent copy of the ARRL handbook.
Resistors are easy to get in bulk, any hobby electonics store will have a big package of various commonly used values of resistors in what they call something like the "Bench resistor kit" or something like that. Same with ceramic caps, small electrolytics, LED's, the like. . .
Also, a decent bench power supply is kind of a must as well, but you can build a good one for cheap using an old ATX power supply out of an old computer.
Finally, I'd say these are the essentials.
Fire extinguisher - You'll never regret having this.
Safety glasses
Chicken stick
Chances are you probably have 90% of this already.
aonomus
Sun Jul 13 2008, 07:07PM
If you go towards pulsed power (coil guns, rail guns, induction launching, just blowing stuff up), you might want to make a pair of chickensticks with a lead + 1watt 1MOhm resistor to discharge. Fiddle with the resistance to get the desired effect, but its safer than shorting out with a screwdriver and won't mess up the caps in the long run.
Sun Jul 13 2008, 08:41PM
Marx generators are also simple and can be put together just by soldering the components together without any boards etc.
These will give nice loud sparks even at small ones, the one I build was my first HV project and you can see it here Link2
combine this project with a flybackdriver and you got something similar to uzzors marx generator that I am very fond of and will build one like it when I need time off from the coils :)
uzzors 180kv marx Link2
Part Scavenger
Wed Jul 16 2008, 01:00PM
This is a really good multimeter for really cheap. I have two of them, and they are as accurate as my $200+ meters. It also measures capacitance and temperature.
I'd start looking for an oscilloscope too. Minimum, you want 20-30Mhz, dual trace. Should be around $50. Sometimes you can get a steal around $20. Just post us and ask us what we think it you like. Look at eBay and the local state redistribution office.
Radio Shack carries a pretty decent soldering iron for first use. Their desoldering iron is good for cheap too. Great for removing flybacks and whatnot.
Oh, and definitely get a breadboard. Last I checked Mouser.com and All Electronics had pretty good deals. A good one should run you about 30 bucks
Oh, and I'd build the classic 2N3055 flyback driver and move up to the Mazzilli circuit. Expect to blow up several 2n3055's.
Have fun!
Ultra7
Wed Jul 16 2008, 01:59PM
Whoops, accidentally posted a reply on the wrong tab.
How are your experiments coming along?
