  • Guests: 50
Check this secondary for me
coillah
Fri Jul 11 2008, 02:15AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Hi
I found a secondary:
OK so is this guy a good seller?
Also I'd like a sanity check on my secondary choice.
specs for my parts otw:
(NST)
15kV output
30ma
(Caps)
24 of the Cornell Dubilier
Shaun
Fri Jul 11 2008, 03:06AM
That seller is reputable, and his items are all good quality. I always stand by the fact its better to make things yourself, but a coil of wire is the same no matter how you get it. Only thing that makes me wonder is the over 6:1 H:D ratio; seems a bit high.
$33+shipping isn't so bad, but there's nearly 6 days left on that auction and my bet is it will go up. A lot. As it is now you could probably build it for a comparable price, and even more so if you use PVC.
EDIT: I should probably mention that I am a *little* inclined to dislike eBay auctions with exclamation points in the title...
coillah
Fri Jul 11 2008, 03:59AM
OK but is the coil in the general range of what I am looking for given my specs?
cjk2
Fri Jul 11 2008, 05:53AM
Everything seems fine with that, but unless you really don't want to, i would wind the coil myself. For probably $20 you can get everything you need to do it yourself.
Shaun
Fri Jul 11 2008, 06:43AM
Yes, that secondary will match your transformer nicely, if that's what you meant.
A lot of people have an aversion to the whole "winding thousands of turns of super-thin wire" thing. I've always found secondary winding to be the easiest part, especially on SGTCs, where you use far less turns of thicker wire as opposed to most solid state coils. And I wind my coils by hand.
A coil like the one you linked to could be wound in well under an hour, which is a small percentage of the time you'll spend building the overall enclosure, MMC, topload, primary coil+stand, and various other spark gaps and EMI filters. Plus you get the added bonus of having it EXACTLY the way you want, instead of working around whatever this guy is selling.
Coronafix
Fri Jul 11 2008, 10:41AM
It doesn't look like it has very much coating on it. It says there are several coats but I would bet
that he just used a can of spray on polyurethane.
coillah
Fri Jul 11 2008, 02:13PM
I still haven't bought it because I need to see if I can't find a cheap magnet wire supply in the SF bay area. If I can find one, and I can get the wire for under 15 then I'll wind it.
It's probably 30% aversion to wiring, 50% money, 20% time that's making me want to just buy one.
But the fact that I can wind it to exact specs means I'll get optimal spark length, and with only 3 feet to work with...
