  • Guests: 51
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Microwave SGTC?
Dragon64
Tue Jul 08 2008, 05:27AM Print
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
Would it be possible to make a SGTC, mostly from parts found in the microwave?
MOC's could be used as capacitors
MOT could act as power source.
Cooling Fan could be built into rotary spark gap.
Several feets of wires for primary winding
Tue Jul 08 2008, 05:30AM
hydraliskdragon wrote ...
I would recommend like two ovens so you can make a voltage tripler and then you could use the fan for rsg or for the wire for the secondary. But, yes it is possible. Link2
Go down to(obviously) Tesla coil made only out of parts from a single microwave oven.
Myke
Tue Jul 08 2008, 06:11AM
Here is a thread about a TC made from only microwave parts.
Tue Jul 08 2008, 09:25AM
if you can find an old monitor / tv and together with the microwaveoven, you could build a small flyback driven sgtc.
like this. Link2
If you would like to do it, please note that the secondary I used should have been thinner and taller, a width 1:5 height ratio would have been better.
Tue Jul 08 2008, 04:46PM
MadsKaizer wrote ...
like this. Link2
Haha, yea or this one Link2 :P
Alexandre
Tue Jul 08 2008, 05:19PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
Steve connor's made a DC Tesla coil, with only one MOT ..
Using a Quadrupler in output, has about 10kv @ 150ma
And spectacular sparks!!!
