  • Guests: 48
Ground Fault Protection Implications
coillah
Mon Jul 07 2008, 12:06AM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
How does ground fault protection affect a power supply such as a NST?
Hon1nbo
Mon Jul 07 2008, 12:23AM
many times it causes the power to shut off under high load, I almost had to remove it from one of mine because it was such a pain... but I found a better supply for the project, so I never bothered, and most all are made with them today so if you have a supply with one, you might look into removing it... but I would wait, as someone here may have a better solution.
Tue Jul 08 2008, 01:39PM
I recently bought a used Resinblock 9kV/60mA NST, its ground fault protection was mounted just under the cover and there was even a piece of wire with it to shortcircuit around the protection.
I also learned that its illegal to install neon systems with a higher voltage than 10kV in Denmark, which explains the lack of 15kV transformers here.
